Damn Need a TP55!
Old Sep 28, 2014 | 08:56 AM
Geeeyejo's Avatar
Geeeyejo
Damn Need a TP55!
Pulled the Ex in the driveway to replace my driver's seat cover today and to my surprise saw just about the largest Torx fitting I ever saw holding the seat down. Quick bit of research showed it was a Torx "plus" 55 - a size not carried by any of my local shops. Some say a T55 works but could result in the fastener head stripping so didn't want to take the chance (would need to buy a T55 to try anyway) Fortunately found a TP55 on Ebay for just under $14. Should one this week and looks like seat cover waits until next weekend...
Old Sep 28, 2014 | 09:28 AM
sessland's Avatar
sessland
I was going to remove my front seats and carpet last week until a helpful member pointed out that I needed the T55, but there was no mention of any "plus".
I've never heard of a plus rating.
Old Sep 28, 2014 | 09:47 AM
Geeeyejo's Avatar
Geeeyejo
It's actually a different torx series for heavy duty applications. A T55 could strip the bolt if you're not careful. Size is TP55 - search on Google or Ebay and you will see what I mean...
Old Sep 28, 2014 | 10:00 AM
sessland's Avatar
sessland
I did search after your post and the best I can come up with is that it's a 2 piece design?
Old Sep 28, 2014 | 10:26 AM
Geeeyejo's Avatar
Geeeyejo
Old Sep 28, 2014 | 10:28 AM
Geeeyejo's Avatar
Geeeyejo
The socket may be two piece but the actual bolt is more rounded in the points of the "star" - a T55 will fit but will have excess play and could strip - a TP55 would fit snug and allow more force to remove the bolts..
Old Sep 28, 2014 | 10:59 AM
sessland's Avatar
sessland
ok I got it now....visual learner
Old Sep 28, 2014 | 06:06 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Do you have to remove the entire seat to replace the seat cover? I did it a while back and didn't think I had to do all that, just the seat bottom. Maybe I'm wrong though haha.
Old Sep 28, 2014 | 09:10 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
I removed my entire interior earlier this month to sound proof the truck. I had no issues using my T handle torx set to remove everything. My T55 worked just fine for the seats. I had no issues at all with fitment or stripping. I did have to slide a screwdriver into the handle of the torx to give me a little more leverage to break the bolt loose. Just apply enough downward pressure and take your time and you should be fine.
Old Sep 28, 2014 | 11:37 PM
superdave02f552's Avatar
superdave02f552
Agreed used a snap on t55 for my whole project jus have to keep steady pressure not a fast jerking motion or impact use leverage
Old Sep 29, 2014 | 09:32 PM
Geeeyejo's Avatar
Geeeyejo
Not saying it can't be done but looks like it will make things a lot easier as the plastic panel on side looks like it needs to be removed as well - will post pics this weewkend
Old Sep 30, 2014 | 12:49 PM
ExploringNH's Avatar
ExploringNH
I used a T55 on an impact and everything came out without stripping. It was loose but not loose enough that I was too worried about it.
Old Sep 30, 2014 | 05:54 PM
slowlanemcvane's Avatar
slowlanemcvane
...Loose but not loose enough that I was too worried about it...
Reminds me of a girlfriend I had once...
Old Sep 30, 2014 | 10:31 PM
superdave02f552
Originally Posted by slowlanemcvane
...Loose but not loose enough that I was too worried about it... Reminds me of a girlfriend I had once...
LOLOLOLOL,,,,,,
flatbedfordguy
Jun 18, 2018 01:47 AM
cocoband88
Feb 9, 2017 03:50 PM
NashvegasMatt
Sep 29, 2016 07:06 PM
Timo2
1997 - 2003 F150
Oct 28, 2013 02:43 PM
VinMan
1978 - 1996 Big Bronco
Aug 18, 2004 10:27 AM
