Fixable hub?
Old Sep 26, 2014 | 09:01 AM
christurney77's Avatar
christurney77
Fixable hub?
Should I try to fix this, or come up with another hub?
There is some nasty hammered spots on the end that have made getting the old race out and installing the new race difficult. Being what it is should I even try fixing?
Old Sep 26, 2014 | 09:22 AM
critterf1's Avatar
critterf1
Easy fix. I do it all the time.
Old Sep 26, 2014 | 10:16 AM
ALBUQ F-1's Avatar
ALBUQ F-1
How?
I'd replace it, shouldn't be hard to find. I'm sure you could dress the high spots out to let a new cup be pressed in, but if the surface isn't completely uniform, bearing life may be short. Bearing mfr's want a specific press fit to hold the cup. Only a machinist could tell if the hub is still a perfect circle (not oval) and no high spots. A lot of work if you could just replace it.
GlenPxC
Jan 23, 2019 11:24 AM
texbigred1
Nov 2, 2016 09:32 PM
Patchy 73
Australia Chapter
May 3, 2015 06:29 AM
elwood9270
1997 - 2003 F150
Jan 18, 2014 09:14 AM
98150
1997 - 2003 F150
Apr 6, 2004 09:27 PM
