Piston Rings
Old Jul 14, 2003 | 09:35 PM
mahull's Avatar
mahull
Piston Rings
Rebuilding a '92 302 for a 4WD F150. To my surprise, found out that the engine had already been rebuilt (0.030 over pistons), before it ever left the factory. Heard that some >1980s vehicles come this way. Very disappointing.
Nevertheless, replaced all but cam and roller lifters (little to no wear) and pistons. Rebuild is going quite well with one exception: piston rings sent in engine kit are too thin and all local parts stores show the same ring (i.e., its not a labelling issue, etc.). Diameter and width seem okay, just a thickness problem (or height problem if you envision laying the ring flat on a table). Not sure how to go about obtaining the correct rings economically (emphasis on "economically"--already spent enough for a short block). Any tips would be much appreciated.
Thanks
Old Jul 15, 2003 | 12:06 AM
bearfoot_25's Avatar
bearfoot_25
Piston Rings
get rings for the older 302. try like an 81 or up 302 and i bet youll get the right ones.
