How To: 65-66 parking brake assembly
I used white acrylic paint and a small hobby paint brush to repaint the BRAKE letters on my F100. The F250 restoration is going to require quite a bit more work though since I'm changing the front cable to the slightly longer PS specific front cable. The '75 edition only shows the PS specific cable as being for the F100, but it also doesn't show any of the cables for a short bed, and I'm pretty sure they came with parking brakes and didn't have excess cable looped up under the truck somewhere. My F250 is also in much rougher shape than my F100, so I might send it out for re-plating as you suggest..
The OSI Volume 4 might list older cables but figuring out what was what might take a little doing. The non-PS front cable for the F250 is still available NOS, but without a part number for a possible PS steering specific front hose I wouldn't know what to look for exactly. Does the '68 MPC hard-copy list the other cable?
I believe I have 3 of the ones listed in the '75 edition.
C5TZ-2853-P
If there was one for the F250 with PS it would have also been 1966 number so C6TZ-2853-? Seems like it would be the same -C suffix. I don't see any of those anyway.
My wrong part, mustang brake handle, is still sitting on tool box. This is encouragement to to take assembly apart and see what I can do with the broken handle.
Another note. When I first got my 65, the parking brake could not be pulled and engaged.I figured the cable and pivots were all rusted frozen under body. I started working on getting all dash wiring and lights working. I noticed once I'd crawled up there, that the wrapped wires leading to the fuse block were pulled tightly across top of this tube and rod assembly holding the stop pin from moving at all. It stopped things alright...just not as intended. These trucks can be puzzles in so many ways. We rarely know what they've been through in 55 years. Such satisfaction when things all start coming together
What I found worked best for me was to loosen the slack, or remove the cables at the equalizing bar to the rear drums, then install components from the handle to the bar. I then would install, leaving slack in the cables until the rea brake cables were installed and then adjust the tension from the equalizing bar to the drum.
Sorry to heating up this old thread but I'm running out of ideas where to get a parking brake assy.
I have imported an 65 F100 2 wheel drive to Germany, for his age in good conditions, all chrome, emblems etc are still original and no dent's and the body needs only minor work.
Unfortunately one of the earlier owners installed some new gauges under the dash and removed the parking brake assy below the dashboard (and w/o that one no license in Germany) to have enough space.
So I started looking at official parts stores (LMC,...) since I made good experience wrt parts availability for my other US truck there --> nothing available.
Then to ebay... also nothing.
Then I used the free internet search and found this great forum where you posted already other sources to check for (Rearcounter,..) but also there is nothing to find.
Part number is 2780 in the OEM parts catalog.
Has anybody an idea or an contact I can use to find one of this (rare) parking brake assy?
Thanks and Grt from currently snowy Dresden in Germany.
Jens
Since that part is not reproduced and I’m assuming that you don’t have junkyards in Germany that are stocked with old American trucks...your best bet is probably through this website. Post a wanted ad in the classifieds here and keep posting in the forum. There are a few members here who visit the wrecking yards and some who have parts trucks. It may take some time. Also check withTurner auto wrecking in Fresno, California. They have miles and miles of older American vehicles. You can probably email them, though, shipping is another story. One more thing...make sure to look at the diagrams and get every single part you need for the hand brake assembly. The main assembly won’t help you if you’re missing a small part that goes with it! Good luck....
Another thought....start a new thread with appropriate title, such as, WANTED parking brake.... If you’re not a stickler for originality, you can also convert your hand brake to a foot-actuated parking brake. I got a foot-actuated brake assembly from a 74 truck and its much more convenient than a hand brake.
1965 1966 Ford F100 F250 F350 Truck NOS PARKING BRAKE HANDLE LEVER ASSEMBLY | eBay
There are also floor mounted levers that I'm sure you can buy in a kit that could be used. Try searching on Lokar, I'd guess they make something.
thanks for you quick answers and possible solutions. Will check with our official if an electronic operated brake is allowed and I also contacted Kathy and Tom from Flasback, hope they can support. If not than we will go for an foot operated ones.
Again, thanks for your input, great support here.
Grt from snowy Dresden in Germany
Jens
