F1 Explorer 8.8 Swap Question
Old 09-24-2014, 09:03 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Originally Posted by TonyB55
Hi Gary, I noticed from the pictures in your gallery that your front sheet metal is 1948-1950. ...
It appears your cab is a 51-52, the bed is late-50 or later, the front end 48-50. I'd check the serial numbers on the frame ASAP, to see if it matches the title. If you post the serial number we can decode it for you.
I could see someone putting a D41 3.73 axle in the truck if it originally came with a 4.27 D44. Can you tell what trans it originally came with? It should say on a plate in the glove box.
Old 09-24-2014, 09:32 AM
AXracer's Avatar
AXracer
AXracer is offline
I spoke with Gary at length on the phone last night. He is quite aware that the front clip and cab are different years. He bought the truck completely disassembled sandblasted and primered. He's still sorting out just what he has and doesn't have. I'll likely head over to his place this weekend (he's about 30 min from me) and take a look.
Old 09-24-2014, 09:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
What is the serial number, compared to the title?
Old 09-24-2014, 11:43 AM
jgp1952's Avatar
jgp1952
jgp1952 is offline
Hi Gary, I noticed from the pictures in your gallery that your front sheet metal is 1948-1950. It could be possible that your frame is also that same vintage, as they came with the Dana 41 vs. the Dana 44 that would be in a 52 model.
I can't imagine why anybody would have swapped a Dana 41 into it.
I also have an explorer axle with 3.73/traction lock/disc brakes that I'm putting
into my 1950 F-1. The Explore axle is 2" narrower than the Dana.
I'm keeping the original ride height on mine, so I can't help you with lowering advice.
Axracer was kind enough to help me out with my project, especially with guidance in frame and suspension matters. He really knows what he's talking about and saved me a lot of grief by heading me in the right direction.
The 3.73 gears will be nice behind the AOD transmission. I'll be using mine with an AODE. Basically the same as the stock Explorer.
BTW, I'm about 20 miles south of Raleigh.
Good Luck!
Hi Tony,
The guy I bought the truck from didn't care for the "Teeth" on the stock 52. He found a 48 F1 front end at a swap meet and swaped the front sheet metal. As far as the rear axle, I spoke with Axracer last night and he said that it is not uncommon for odd combos like this. At the time of assemby, due to war, Ford assembled cars\trucks with whatever they had in stock. The cool thing is all parts from 48-52 are interchangeable.
As soon as my account here is fully enabled, I will PM you with contact info. I live in South Raleigh near Garner. I'd like to check out your truck and see what you have done.
-Gary
Old 09-24-2014, 02:04 PM
TonyB55's Avatar
TonyB55
TonyB55 is offline
Originally Posted by jgp1952
Hi Tony,
-Gary
Hi Gary,
I just sent you an email with my contact info.
Tony
Old 09-24-2014, 06:24 PM
rhopper's Avatar
rhopper
rhopper is offline
48 F1 here. All my stock parts were beyond repair, so I bought a TCI leaf spring kit with brackets. 8.8 explorer axle over the springs. 3.55 ratio. The spring kit lowered the rear 4", matching the front end. I used some spacers also to get the tires alittle further from the box. At 4" and axle over the springs, you'll need to do a c notch to keep enough travel. My setup is leaf spring only, no sway bar. Price out the rebuild of the stock components and then price a kit. You may be money ahead just replacing the whole thing.
Old 09-24-2014, 07:34 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
I got mine 8.8 inch out of a junk yard as well, 3:73 posi disc brake set up, welded spring perches on top and bolted right in my 56 f100, I did away with the sway bar stuff, it rides good no issues.
Old 09-24-2014, 08:28 PM
topmoo's Avatar
topmoo
topmoo is offline
I also installed TCI leaf springs and an 8.8 2000 Explorer rear, 3.73 limited slip, with disc brakes. I got perches for 3 1/4" tubes and installed it under the springs. No sway bar on mine either. I have just done little bit of driving so far, but it seems to handle just fine. BTW the emergency drum brake works well too.
Old 09-25-2014, 09:27 PM
garm59's Avatar
garm59
garm59 is offline
8.8swap to 49 f1
I am getting started on my 49 f1 project,and am getting tons of info from FTE.THANKS GUYS.I plan to use 5.0 or 5.8 AOD & 8.8 axel.My question,is there any issue with the 8.8 being offset 1-2" to passenger side[stock pinion is centered].Also,some have said they needed wheel spacers.My stock axel measures 59.5 wheel to wheel & 8.8 explores axels I have seen on line claim 59.5 also[95 thru 01].Thanks again
Old 09-25-2014, 09:58 PM
cokeb5's Avatar
cokeb5
cokeb5 is offline
I am in the process of installing an 8.8 in my 56 and I will need wheel spacers,not sure if that is true with the f1. The area I'm seeing an issue is clearance between top of the center section and the bottom of the bed. My truck is lowered but not as low as many trucks I see, I only have 3" of clearance. Might be something to ask th f1 crowd if you plan on lowering.
craig
Old 09-26-2014, 08:13 AM
AXracer's Avatar
AXracer
AXracer is offline
yes the 8.8 will require about 1" spacers depending on wheel width and offset. disadvantage = cost, advantage = spacers can also be used to change bolt pattern to match front so you can have same bolt pattern all around.
Old 09-26-2014, 05:48 PM
garm59's Avatar
garm59
garm59 is offline
49 f1 rear axel
My bad. I remeasured my stock rear axel,it is 61" wheel to wheel.Not 59.5" as I said earlier so spacers will be needed. still would like to know if off set explorer 8.8 pinion is an issue.do I need to offset motor to match pinion or is the 1" to 2'' offset not a problem. THANKS.
  #28
Old 09-26-2014, 06:07 PM
rhopper's Avatar
rhopper
rhopper is offline
The offset pinion is not an issue. The drive shaft only sees one angle, it doesn't care if it's up, down or side to side. I used wheel adapter spacers and changed my bolt pattern to match the jag ifs. Don't remember if they were 1" or 1.5". Clean the mounting surfaces, torque to spec with locktite. Check it after a few miles and you'll be fine. The 4x4 guys use spacers like this without problems.
  #29
Old 09-26-2014, 09:51 PM
garm59's Avatar
garm59
garm59 is offline
8'8 exp.offset
thanks rhopper for the info.1 less thing to worry about.
  #30
Old 09-27-2014, 01:20 AM
Trey_Morgan's Avatar
Trey_Morgan
Trey_Morgan is offline
Here is a 2000 2wd explorer 8.8 with trac-loc and 4:11 gears in my '51 F-1.
Quick Reply: F1 Explorer 8.8 Swap Question
