Modded Suspensions Call - Request your measurents
#226
Did you add any leaves on the back, or anything other than the blocks?
Some add the helper to the bottom, or a leaf from the Ex spring pack, or the traction bar from the Ex to get extra lift, which I dont need since my F350 springs up front didn't change my ride hight.
Thanks
Thanks
#227
Thanks
Thanks
#229
unknown to me if the driver side is low or if the passanger side is high but either way they are not matched.
#230
Thanks
Thanks
#231
Whatever the ATS Modified C’s are, not sure of the specs.
I highly doubt ATS would screw up like that. Junior handled the order and we spoke about the situation.
#232
#233
Doing the math, your 28.5" - 23.75" average stock - 2" for the block swap =~ 2.75"for the Mod Cs.
So far I have:
B codes ~ 1.25 over OEM
C Codes ~ 2 over OEM
ATS Mod C ~ 2.25 over OEM
Now I need data on the F codes.
I had air bags on a Cherokee and they stiffened things out even at minimum pressure.
From my research the Ex has stiffer/ flatter springs for ride height while the F250/350 springs are softer initially with ~ 2.5" more arch.
Thanks this helps a lot!
So far I have:
Last edited by Essayon; 12-19-2018 at 02:18 PM. Reason: Reduced Mod C lift based on OEM block size.
#234
So far I have:
ATS Mod C ~ 2.75 over OEM
So far I have:
#236
Essayon,
I like the C Codes as the ride is firm but comfortable without a camper. I have a 7,000 camper I tow and have towed on one extended trip before I had the motor bulletproofed along with other work. It towed really well but was getting a little sway. I feel this sway was due to me not having the WDH fine tuned.
#238
#239
Front Left 25"
Front Right 24 15/16"
Rear Left 26"
Rear Right 25 15/16"
Front Dana 60 Axle
(I'm sagging right a 16th of an inch) - OH Well
ProComp aftermarket springs 22210 Front 22415 Rear with one spring leaf removed both front and rear and no rear blocks at all
Adjustable track bar
Rear Left 26"
Front Dana 60 Axle
Today my measurements are
Both front 24.5
Both rear 25.5
I fixed that sagging right side due to a slipped shims some time back, so with that fix I started at approx 25 front and 26 back after the entire build was completed and tweaked. So by my math it looks like I have dropped roughly a 1/2 inch in 5.5 years
#240
