Problems with A/C ???
Old Jul 14, 2003 | 05:19 PM
Wheelman's Avatar
Wheelman
Question Problems with A/C ???
Hello my girlfriend and I just bought a 97 Ranger XLT V6 Auto, and it is a really nice truck with the exception of one problem. When you use the air conditioning on MAX AC it works fine and blows cold but when you but it on regular AC it starts to blow hot. Any ideas what the problem is and how I can fix it?? Please use baby steps if possible, I'm just a kid-corvette mechanic and have yet to tear into the ranger whatsoever.
Thanks In Advance!
Old Jul 15, 2003 | 08:34 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I would start my checking the air blend door, you should notice an air flow change when changing from hot to cold with the blower on high. When you switch to max AC the coolant flow to the heater core is turned off, thats why you get cold air then. The tech info post has a link to a fix, to replace the plenum you need to remove the entire dash.
Old Jul 15, 2003 | 11:55 AM
zAoemaster's Avatar
zAoemaster
I Have question about the ac in my 99 Ranger XLT V6 Auto 4x4 every time i put on the fans( hot or cold) the ac comes on. how can i fix this
Old Jul 15, 2003 | 12:14 PM
greenpus's Avatar
greenpus
THat's how Ford designed it. The only time the compressor isn't running is when the selector is on "vent only" or "floor only"
Old Jul 15, 2003 | 12:55 PM
Wheelman's Avatar
Wheelman
Originally posted by Ken00
Welcome to FTE!!!
So if im understanding this right, then the most common cause of this problem is the actuator pin that drives the blend door breaking??
Old Jul 17, 2003 | 06:07 PM
Wheelman's Avatar
Wheelman
ttt
Old Jul 17, 2003 | 08:10 PM
Ken00's Avatar
Ken00
I have not done the fix but the info seems to indicate the area on the blend door breaks were the accuator pin connects.
Old Jul 18, 2003 | 03:04 AM
zoti's Avatar
zoti
I had just done the blend door fix for my 96 Mazda B2300 and it works like a charm. It's easy to understand the instructions but note that it's hard to stick you hands in the space above the air box and you MUST have a small dentist's mirror to see the way the door pin broke. Have a good look at the way it broke to plan you drilling and pin positioning. If you do it right you can get it in one go. Just like I did :-)
The whole thing should take about an hour to do if you are good with your hands.
It's a pitty you live that far away. If you drive up to Dallas I'll be happy to help you fix it.
