carb swap
Old Jul 14, 2003 | 04:20 PM
travis c's Avatar
travis c
carb swap
i have a 351m in a 76 f100 that i would like to get more power out of. if i got a carb of a 400 and put it on my 351m would it add any power, what kind of mileage would it get?
Old Jul 14, 2003 | 07:00 PM
bubbaf250's Avatar
bubbaf250
carb swap
In most applications, the 351M and 400 used the same carb calibrations.
If you want to improve power with the stock carb, try the following:
1. Add the Motorcraft 5/8" phenolic spacer (part # CM-3545A, about $15 at any Ford dealer) under the carb and above the EGR spacer.
2. Increase the main jet size (by 2-4 numbered sizes) and install a power valve that opens at a lower vacuum (say 6-8 in/Hg or less).
Check out the following page for more details:
http://home.earthlink.net/~bubbaf250/perf/perf02.html
