Hello Ford users:1990 E350 Air Con. Swap? Altnator gauge stuck? Just got a crew cab pu. diesel (7.3?) 2WD A/T (8') Was told "thats a 1 ton suspension. Anyway, been sitting on the docks ( san francisco)1.5 yrs but fired up after some cranking. sounds good at 65Kmi all tho beat up for $1200 who cares As to the Qustions (1) Air compreser not engageing(air con) if I need one will one off a gas engine work? what yrs & from what motors (2)Alternor gauge stuck(?) over on full charge position?. Had charging system checked & its OK & working normal ( shall I bang fist on dash over gauge area to unstick? (3) Has no tailgate "what years & models" will fit this beat-up work truck. I don,t like neting type or droping in a board, but will any F150 -250- or 350 work? (4) Last both tanks are about 1/2 full shall I try to (A) run it out (B) drain it (C) Add to it.
I plan on cleaning the injectors via cleaner in the fule filter
Thanks Conrad
Thanks Theo: Found out the tailgates are the same from 87 / 91 its in the latch thats different. Early might fit but not latch - if I had the latch - switch ?.
Changed the fule filter / water seperator & now it don't start - expect air in the lines ? how do you get it out ?
Was thinking back-off the lines at each cilender till fule pumps out ?
WHATS THE RIGHT WAY TO CLEAR THE AIR OUT ?
