freon loss
Old Jul 14, 2003 | 01:23 PM
az_hiker's Avatar
az_hiker
Cool freon loss
1994 Ranger XLT. 2.3L. 5sp. 150k miles.. R134A factory
Live in AZ..hot.. anyway, freon leaks out every day or two.
I have replaced both hi and lo valves. They were leaking at different times..loudly.. Took it to the shop.they charged $120 to leak test and recharge. They can find no leak? I am taking it back this afternoon since it leaked out again. They, of course, put die in it..which will help them find it..hopefully? But I had also tried die..to no avail..
Any ideas??
thx.
Old Jul 14, 2003 | 02:11 PM
mantta's Avatar
mantta
freon loss
Did they check for leaks around the evaporator? They do leak sometimes. The best place to check if you are using an electronic or halide leak detector is the condensate drain hose since refrigerant gas is heavier than air.
Old Jul 14, 2003 | 04:05 PM
steve83's Avatar
steve83
freon loss
FYI:
R-134a is called "Suva"; R-12 & R-22 are called "Freon".
Just trivia...
Old Jul 14, 2003 | 06:22 PM
jim henderson's Avatar
jim henderson
freon loss
Most shops can inject some UV dye that will show up under black light when it leaks out.
A knowledgable shop would probably have tried this. You can even buy the stuff at some parts shops.
Good Luck,
Jim Henderson
