e4od?
Old Sep 11, 2014 | 02:19 PM
fordguy62's Avatar
fordguy62
e4od?
Would an e4od bolt up to a 351w, from my readings i believe it can. i can get one for 100$ and the guy said it was working fine before he pulled it out of a 98 econoline
Old Sep 11, 2014 | 02:22 PM
dlburch's Avatar
dlburch
what was it bolted to in the van?
Old Sep 11, 2014 | 02:25 PM
fordguy62's Avatar
fordguy62
he said it was a 5.7l
Old Sep 11, 2014 | 03:51 PM
buckin69bronco's Avatar
buckin69bronco
'98 econoline had moved on to the mod (triton) motor, this will not fit a 351w. Ford never made a 5.7, options for '98 vans were 4.6, 5.4 or 6.8 (v10).
Ford did make E4OD's that will fit your 351w, any 300, 302 or 351w from a 1987-1996 econoline or f150 and 87-97 f250 or f350 will fit.
Old Sep 11, 2014 | 05:35 PM
HIO Silver's Avatar
HIO Silver
Big broncos also used the E4OD too, right?
Old Sep 11, 2014 | 05:56 PM
buckin69bronco
Oops, yes you are correct.
Old Sep 11, 2014 | 09:25 PM
fordguy62's Avatar
fordguy62
Would it fit a 93 460?
Old Sep 11, 2014 | 09:36 PM
blue04.5's Avatar
blue04.5
Fordguy are you sure your bud didn't say 7.5L(460 IIRC)?
Old Sep 12, 2014 | 10:23 AM
fordguy62's Avatar
fordguy62
it could have been a 7.5l and he just mixed it up when he told me. if thats the case it would work with a 93 460 then right? anyway to tell just by looking at the transmission?
Old Sep 12, 2014 | 12:31 PM
fitzmotor's Avatar
fitzmotor
The trans part is easy (sort of) but you MUST have the factory processor or a aftermarket trans controller (US Shift/Bauman) to run it on one of our older trucks, then you add a TPS sensor to the carb (Holley Makes one) RPM signal and a Vehicle Speed Sensor, they work well, they are expensive.
Or you can sort out the factory ECU and loom, if you do that you may just fuel inject the truck.
I was going to do the swap but I would have to shorten or change the front gas tank (E4OD is longer) so I went with the 1st and 2nd gear out of a E4OD in my C6 to give it a wide ratio instead.
Old Sep 12, 2014 | 03:02 PM
fordguy62's Avatar
fordguy62
Do you have any links as to exactly what parts i should use?
It will eventually be fuel injected, so i might go that route
i dont have any front tank so i should be good on the length issue
Old Sep 12, 2014 | 03:21 PM
fitzmotor's Avatar
fitzmotor
The US Shift Transmission Control System
They have everything to control the trans and the TPS kit, it's a easy but expensive way to have a overdrive.
Old Sep 12, 2014 | 05:02 PM
fordguy62's Avatar
fordguy62
thanks fitz now if i went with a fuel injected 460 i would just need the whole computer system from the vehicle that the transmission came from?
Old Sep 12, 2014 | 07:34 PM
fitzmotor's Avatar
fitzmotor
The best year is 97, that E4OD has all the best upgraded internals, but if you want to keep your cable driven speedometer you have to get the early output shaft 92 I think and some of the tailhousings up to 96 have a plug in the speedo hole but not all, some have no hole, I would get the loom and computer from the same year as the trans.
Old Sep 12, 2014 | 07:37 PM
fordguy62's Avatar
fordguy62
ok thanks for the info
timbuctooCal
Mar 2, 2014 09:53 AM
irosbrugh
Aug 17, 2010 09:41 PM
84F100
Feb 27, 2006 09:48 AM
RawPower
Feb 21, 2006 01:22 AM
66F250LH
Engine Swaps
Feb 22, 2005 08:49 PM
