Sponsored by: Real Truck
transmission problems continue
Old Sep 9, 2014 | 07:18 AM
frankiethethumper's Avatar
frankiethethumper
1999 F350 v10 2wd automatic. Truck has been acting crazy for more than 6 months now. Diagnostics machine indicated the PCM thinks the transmission is being manually shifted into 2nd gear when it is clearly not. Code was 0705 Transmission Range Sensor. I have replaced the range sensor, had the PCM rebuilt, and verified continuity in the wires between the range sensor and the PCM. None of the local mechanics seem to have a clue. Any input would be appreciated.
Old Sep 9, 2014 | 10:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have either a bad range sensor or a problem with the wiring between the PCM and range sensor. I bet it's the wiring.
Verifying the continuity is one step to determining if you have a wiring issue. Did you also check each wire for short to ground, short to power, and short to each other?
Old Oct 7, 2014 | 06:04 PM
frankiethethumper
Looks like you were right about the wiring between the PCM and the range sensor. Local ford dealer was able to duplicate the problem by wiggling the wiring harness. Mechanic thinks it is a plug in connector under the hood on the front driver side wheel well. He said he doesn't think it is a connection problem at the PCM based on where he was moving the wires.
Question is what is the best method for fixing it? My thinking is to cut the wires after they exit the PCM plug and before they enter the plug on the TRS, then splice in new wires. Or is it necessary to replace the female wire connectors at the PCM plug and at the TRS plug with each new wire?
Old Oct 8, 2014 | 09:32 AM
speakerfritz's Avatar
speakerfritz
the problem is likely the potions that remain when you cut the wires out. see if you can replace the connecting ends .
zbussey
Aug 2, 2024 10:50 PM
IHateCommieCars
Feb 2, 2021 08:08 AM
Lsvare
Sep 11, 2015 11:43 PM
donehojo
1978 - 1996 Big Bronco
Oct 11, 2005 07:49 PM
