Need help on 99.5 7.3 Powerstroke
Old 09-07-2014, 02:39 PM
Steven7.3's Avatar
Steven7.3
Steven7.3 is offline
I am new to diesels and don't know much about them. Any help would be greatly appreciated. I have a 99.5 f350 with 7.3 powerstroke with 288000 miles. The truck runs great when it's first started but after about 30 minutes of driving it sputters when you try to accelerate and has no power. When it does that blue smoke comes out the exhaust. If you shut it off a few minutes it runs good again for a few minutes then starts the sputtering again. I changed the Cps and fuel filter with no help. The old filter was clean. The oil is full and the hpop is about 3/4 of an inch below the top. Any assistance would be greatly appreciated. Thanks
Steven
Old 09-07-2014, 03:07 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
Steven, have you ever dropped the fuel tank? It sure sounds like a fuel problem. Perhaps the screens on the pickup are clogged, or partly clogged. You might want to do a search for Hutch mod. Easy to do and well worth the effort. The only thing that has me stumped is the blue smoke. That is generally associated with oil burning. Where are you located? Maybe someone in the group is near you that has AE and can check it out for you.
Old 09-07-2014, 03:17 PM
Steven7.3's Avatar
Steven7.3
Nope I haven't I'm in Decatur Tennessee. The smoke is more of a grayish color than blue and it only does it when it's running rough. Not sure if that helps any. I'm new to diesels and don't know much about them gas burners I can work on lol
Old 09-07-2014, 05:10 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
Possible that your EBP valve may be malfunctioning but 30 minutes is quite a while for it to go closed if it opened as it should. Not sure if this is even possible, usually they are stuck closed/partially closed from the beginning.
Old 09-07-2014, 05:33 PM
David7.3's Avatar
David7.3
David7.3 is offline
Checkengine light on? When it acts up unplug the ICP see what happen's, sounds like your running out of fuel, Hutch mod is a must on our trucks, along with rebuilding the fuel bowl, the orings ford used were not meant to be run with ULSD and they fall apart, usually leak but the fuel intake up top can stick closed. When it acts ups open the fuel bowl and look inside, turn the key on should overflow. CPS are known for problems too especesally when warm.
Old 09-07-2014, 06:00 PM
Steven7.3's Avatar
Steven7.3
Nope check engine hasn't come on. I will unplug the icp and try that. After I replaced the Cps it ran great for about a week then started doing the same thing again.
Old 09-07-2014, 06:11 PM
David7.3's Avatar
David7.3
David7.3 is offline
What color CPS did you put in look for black, Gray's seem to lead to problems
Old 09-07-2014, 06:14 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Before you spend any more money, put a fuel pressure gauge on it and see what it is at wide open throttle, under load.
Old 09-07-2014, 06:21 PM
Steven7.3's Avatar
Steven7.3
The Cps I put on is gray. I will find a gauge and check it. Do you tap in by the fuel bowl?
Old 09-07-2014, 07:04 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
This thread may help answer some of your Fuel Press gauge install questions
https://www.ford-trucks.com/forums/1...tall-help.html
And another, with cartoons. I always do better with pics.
https://www.ford-trucks.com/forums/1...questions.html
Old 09-07-2014, 07:25 PM
Steven7.3's Avatar
Steven7.3
Thank you for the links I'm all about pictures.
Old 09-07-2014, 07:43 PM
brushfit's Avatar
brushfit
brushfit is offline
I will say it if no one has yet…WELCOME…..and the information here is priceless….this site and the brotherhood beats the others hands down….I forget there are other sites until someone shares a link with useful info!!!
Old 09-07-2014, 08:07 PM
Steven7.3's Avatar
Steven7.3
Thank you brushfit I look forward to the brotherhood and knowledge!
Old 09-09-2014, 08:57 PM
Steven7.3's Avatar
Steven7.3
Thank you guys for all the help and information. Had a guy bring a computer and run some test. Figured out when it would cut out the fuel pressure was dropping. Dropped the tank and the black pickup tube on the bottom of the sending unit was broke off and the micro filters were clogged up. After a new pickup tube and cleaning the filters it runs as good as new. Thank you guys again.
Steven.
Old 09-09-2014, 09:12 PM
AllaboutMPG
Steven,
To prevent it from happening in the future consider what we call the Hutch mod. Gets rid of the in tank filters so you don't have to drop the tank again. Here's a link to a how to.
Welcome to guzzle's In-tank Hutch Mod Web Page
Or you can do a search using the tab up top and type in Hutch and Harpoon
Glad you got her running again.
Quick Reply: Need help on 99.5 7.3 Powerstroke
