Timing Problems
Old Apr 19, 2002 | 10:42 AM
GammaDriver's Avatar
GammaDriver
Timing Problems
Old Apr 24, 2002 | 06:13 PM
cajunbronco's Avatar
cajunbronco
Timing Problems
Ok here's the deal.I've got a rebuilt 5.0 that is sluggish and eating gas.I advanced the timing to 20 degrees initial(spout out) and it's not pinging,but I did'nt think you could run that much initial timing without it pinging.I ran the #1 cylinder to TDC and the balancer was close to 0,maybe 3 or 4 degrees off.I set it to zero and checked the rotor,it is past the number one terminlal,which I think it should be because it's firing 20 degrees before TDC.Now I have a buddy who says the distributor could be off a tooth.But I don't see what difference that can make as long as you can adjust the base so it's firing in the timing range of 10-20 degrees before TDC.I'm wondering if maybe the machine shop that built the motor put the timing chain on retarded or off a tooth.I know on some timing sets you have 3 keyways,one 4 degrees advance,4 degrees retarded and center or o.Any ideas?The truck acts like the timing is retarded,no power bad mileage.
Billy
Old Apr 24, 2002 | 08:06 PM
Falcon90's Avatar
Falcon90
Timing Problems
The Timing should be set at 10 degrees...but in order to do that you will need to remove a little like plug looking thing on the wire going to the Distributor the little plug is on a wire that comes right off a the distributor wire. remove that and then set your timing and go from there. b/c i checked my timing on my '90 5.0
before removeing that and it said that was at about 17 degrees. and when removed i was at eight.so check that.. Ryan
