Low Oil Pressure
Old Jul 13, 2003 | 04:22 PM
thefireman4652's Avatar
thefireman4652
Low Oil Pressure
I got my engine together with everything new, even the oil pump but I still have low oil pressure after the engine is at running temp.
Start up is at 50psi and after it is running to temp it is like around 19-25 psi.
what is my problem?
thank you again
James and Donna
Old Jul 13, 2003 | 09:54 PM
willowbilly3's Avatar
willowbilly3
Low Oil Pressure
Well if it has 19-25 idleing you don't have anything to worry about. I've even nursed several years out of engines that only had 25 at highwayspeed but it is too low for a fresh engine.
Did you have new cam bearings installed? That is a place where oil pressure can be lost. A lot of people think the bearing clearances on the crank will cause this and they may but I have seen 350 chevys with 2 rod bearings completely hammered out and still carrying normal oil pressure.
Now I have to ask you about your guage. The ones that come in those old trucks aren't worth a flip. So if you are going by that you need to recheck. I have a good mechanical guage on a grease gun hose that I screw right into the engine to check oil pressure with. On my 72 300-6 I thought it was low since thats what the dash guage showed and I checked it with the mechanical and found that I actually had 50 psi at high idle so I put a mark on the face of my guage with whiteout.
I must tell you though my expertise is not so much with engine internals although I have been inside of quite a few, only 3 FEs I think. So maybe someone who is more proficient with the internals will offer something here. If not let me know and I will dig out some service manuels and research the oilflow path and see if I can get some more ideas.
Old Jul 13, 2003 | 10:17 PM
Mil1ion's Avatar
Mil1ion
Low Oil Pressure
Please start another thread rather than high-jacking
a special thread.
Old Jul 14, 2003 | 07:59 AM
KCampbell's Avatar
KCampbell
Low Oil Pressure
I don't see anything wrong with your readings.
In my newly rebuilt motor I idle at just below 25 PSI and it runs at around 50 when cruising along. Both readings are with the engine thoroughly warmed up.
Kevin
GBTUNDRAQUEEN
S. California Chapter
Nov 19, 2013 11:31 AM
GBTUNDRAQUEEN
New Member Introductions
Nov 14, 2013 07:24 PM
stu37d
May 17, 2012 06:04 PM
white Buffalo
41
Feb 28, 2008 06:51 AM
