Total Rebuild Cost
Old Sep 5, 2014 | 03:53 PM
9228.bobcat's Avatar
9228.bobcat
If it is hydrolocked it won't turn over.
Old Sep 5, 2014 | 04:13 PM
Skip1970's Avatar
Skip1970
it might try to turn over as its bending the rods.
Old Sep 5, 2014 | 05:35 PM
r2millers's Avatar
r2millers
Originally Posted by uh60
I am wondering if the guy hydrolocked the engine. Would the truck still turn over if it was hydrolocked?
Depends on how much damage was done. You can have moisture in the egr and still have the engine run, providing the egr cooler leak isn't too bad. Once it splits and starts to "pour" coolant into the intake, you can bend connecting rods, push rods, pretty easily.
IMO, I'd carefully see if it turns over anyways. Not much to lose if it's lunched. If it does turn over, You might connect up diagnostics if possible to measure IPR % and ICP psi in case the issue is a crank, but no start problem.
Old Sep 5, 2014 | 09:06 PM
uh60's Avatar
uh60
Thanks for the info guys.
Old Sep 6, 2014 | 09:02 AM
69cj's Avatar
69cj
You might try taking the glow plugs out first. Won't bend stuff then if it is full of water. Don't look in the holes when cranking. High press. liquid can injure or kill.
Old Sep 6, 2014 | 09:18 AM
maxtruck00's Avatar
maxtruck00
RULE OF THUMB
figure out what its going to cost, double it; thats what its going to cost
Old Sep 6, 2014 | 10:13 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Just something else to keep in the back of your mind, it can hydrolock, then the the fuel or coolant can leak by the rings if it sits a while. Then it may turn over some and lock again. Not saying I suspect that's gonna happen, just that it could. If it turns over some and then stops don't keep trying, pull glow plugs as mentioned above. If fuel comes out of a hole pull injector for that cylinder and inspect for it to be leaking or broken. if you get coolant, pull EGR valve and check for coolant there (if it doesn't have an EGR delete), if it's dry suspect heads/gaskets and wet leads back to EGR cooler.
Good luck! This could be an awesome deal for you if the engine turns out to be repairable.
Old Sep 6, 2014 | 10:52 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
(shameless plug for Anthony)
Old Sep 6, 2014 | 03:16 PM
05F250DSL's Avatar
05F250DSL
Being an 05' it could also have a failed stc fitting. Around a $60 part to fix. That wouldn't account for loosing fluid but is a somewhat common thing that will cause a no start.
0500757Arf
General Diesel Discussion
Mar 3, 2018 09:58 PM
mrgrayaz
North Carolina Chapter
Oct 16, 2017 04:21 PM
SATX210
Jul 12, 2016 04:07 PM
GoCamping
Jan 10, 2015 08:00 PM
dutchhman
Aug 17, 2010 02:09 PM
