Replacement exhaust manifold question
Old Sep 3, 2014 | 01:15 PM
Macke's Avatar
Macke
Hi guys first post here, but I purchased my first pickup about a month ago for $600. 1985 f150 with a 351W. All in all pretty good condition but needs some work, I wanted a project. I found a suitable replacement exhaust manifold for the current one that is cracked, and loud as can be, but it's a little rusted and dirty. The rust I can take care of, but I'm wondering if I should snake the inside of it or if I should just leave it alone and drop it in..
I have pictures if needed but only have my phone for internet so uploading is a pain
Old Sep 3, 2014 | 01:23 PM
CountryBumkin's Avatar
CountryBumkin
I suppose it depends on where you got the manifold from. If it was laying around on the ground at the salvage yard, I would look inside for nests and such, but the entire manifold is only like 14" long so it shouldn't be too hard to check for obstructions.
You should also check the flanges for warping. Lay a straight edge across the mating surfaces. If it is excessively warped you may need to take to machine shop for resurfacing else you could have a hard time getting a good seal.
Old Sep 3, 2014 | 01:25 PM
84StraightSix's Avatar
84StraightSix
Personally I would get it as clean as possible inside and out.
Old Sep 3, 2014 | 01:34 PM
Macke's Avatar
Macke
It was all connected, I didn't see anything but some light carbon build up inside, but will go ahead and scrub it out. I also noticed my current exhaust has a pin that rotates around when the engine is running, it sits right where the manifold connects to the pipe, but I have yet to see one on another engine.. Any ideas on what it might be?
Old Sep 3, 2014 | 01:47 PM
84StraightSix
Im not sure what that might be.....I know on my 300 6 there is a flange that opens when the engine warms up. Its supposed to help in cold weather.
Old Sep 3, 2014 | 01:55 PM
Ranger80's Avatar
Ranger80
If you're interested in keeping the stock style exhaust system, I'd ditch the manifolds and find a quality set of shorty headers instead.
Old Sep 3, 2014 | 01:58 PM
Gary Lewis's Avatar
Gary Lewis
If yours is the HO with a Holley carb then I think what you are seeing may be the heat riser. It is an add-on piece at the exit of the driver's side manifold. Only the HO's had that from what I've seen, and I believe the HO manifold is about 1 1/2" shorter to account for that. So the new manifold should fit as its length is about what the HO manifold plus heat riser's length is. But you should check that first as the exhaust pipe isn't likely to accommodate much difference in length.
Old Sep 3, 2014 | 02:11 PM
Macke's Avatar
Macke
I'd love to get a set of headers, but I'm working on a down payment for a house right now, so it's gonna have to wait unfortunately.
Not sure what HO is but it has an edelbrock carb on it.
Old Sep 3, 2014 | 02:16 PM
84StraightSix
HO = High Output
I believe the only difference from a non HO is the carb and the cam
please correct me if im wrong
Old Sep 3, 2014 | 02:22 PM
Gary Lewis's Avatar
Gary Lewis
Yes, the 351HO as it was called was a souped-up 351W with a different cam, a 4bbl cast iron intake, and a Holley-made carb. As said, the exhaust had a heat riser valve on the outlet and there was a little valve in the heat passage of the intake manifold as well, with both being controlled by vacuum.
Old Sep 3, 2014 | 05:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
In '85 an HO would have Duraspark II ignition and a Holley for Motorcraft 4180 carb.
A regular 351W would have TFI (EECIV) and a 2150 two barrel 'feedback' carb..
LVExp
Jul 10, 2019 09:42 AM
browntown3
Nov 9, 2010 07:21 PM
55 f350
17
Mar 27, 2008 02:11 PM
dillon
Sep 25, 2000 02:02 AM
