LT tires for my fifth wheel
#46
#47
On a 2007 Forest River fifth wheel triple axle toy hauler I almost bought.. Almost because some dipstick changed out the wheels and tires to ST225-75-R15 LR-D from the spec'd LT235-85-R16 LR-E tires...
Sorry for the fuzzy pic..
The toy hauler. I just purchased and towed home has ST235-80-R16 LR-E tires that look good but are timed out.. I can't afford the G614's this go around, but they will be on it next time unless I can install two at a time starting on the rear axle..
Any thoughts on that?
#48
#50
ST vs LT Tires for 5th wheels
This is a tough thread to read. But, of course, I have an opinion (as we all do).
ST tires should be used on travel trailers and 5th wheels, and not LTs. ST tires are designed for travel trailers and 5th wheels: The trailer suspension design specs assume that ST tires will be used. etc. As someone noted a long time ago, going to LT tires will change the design analysis of your trailer..
ST tires should be used on travel trailers, and Lt tires should only be used for trucks.
that's it . . . . ken. . .
#51
#52
I guess the mfg's didn't get that memo because some rv's are coming with LT tires from the mfg ...
At least my mfg put them on and I LOVE them...
Now, can a mfg call a tire an LT if it's not ? dunno, but maybe they can mix and match to have an LT RST
http://www.discounttiredirect.com/di...yp=Truck%2FSUV
so far, we can still use what we want to until the next executive order comes out
#54
If you can ever get to see a G614 prior to install, look at the difference between one and say a China bomb. HUGE difference. The GYs are twice the weight and MUCH better made. I have a TT toyhauler also that has ST tires on it, mainly because they are Maxxis and fall well within the weight designation. As for heavier 5ers, I will use the heavy duty LT tires from now on.
#55
#56
Right! When I took my brand new tires and rims off my RV and to the shop to get the GY's put on, I had to load all 8 in my truck bed. I was astounded to find that the ST tires still mounted on the rims weighed FAR less than the bare G614's! Ken has clearly been reading the ST tire manufacturer's literature and believing it. LOL. For some, the coolaid is tasty and easy to swallow. Anyone in the know, knows its just their marketing. And as jdadamsjr pointed out, LT tires come on some better rigs or can be ordered from the factory. Heck, Michelin even states that their XPS Rib is suitable for trailer use. Goodyear re-designated the 614 for trailer use when it's LT use became obsolete. ST is not a better design for trailers. It's a marketing tool for it's manufacturers and a way for RV manufacturers to use the least expensive tire possible...
#57
Not true Scott. If you ever had them unmounted side by side, you'd see the ST will flex like a cheap bicycle tire and the steel carcase LT will hold its shape even empty. The LT is much stiffer but one of the bogus marketing lines from ST manufacturers is that they have a stiffer sidewall which simply is not the case...
#58
What I found out too late was the Carlyse 15" tire was crap, as it came on my brand new Forest River 5'er I figured they had it capably equipped. It took about 4 trips for me to replace 3 of them with GY Marathon crap tires, but on the interstate having just blown 2 tires you don't have many options.
I have now gotten the Maxxis tires (I think) as I wasn't thinkning I would see this superb post I wasn't ready. So heres a million $$ question, what is the biggest/BEST tire for a 15" rim?
My, apparent, issue is the tires are recommended (or the dealer mentioned this) for speeds up to 65 MPH. Well I took it to Myrtle this summer and ran it 75-80 mph in July and they have done fine ..... so far. I'm fearful that I really need to get some 16" rims for my style of driving, plus the fact that I only have about 600-700 lbs "cushion" per tire of the load limit.
I've had 3 tires total blow out and they all came after crossing a bridge, we all know how great and smooth those transitions are when pulling.
#59
#60
Unless you upgrade to 16" rims, the Maxxis tires you have are are the best in the industry for a 15" wheel and the only ST tire without a huge following of hatred in the RV community. Had them on my first TT and they performed flawlessly!
