I do think I am a bit low on boost so it will need to be addressed sometime before next spring I think but I don't believe I will worry about it before then.
You're low on something alright....
BTW, nice job only stalling the Mustang once last night.
Only if I am standing outside the truck whistling.
Sounds like something you would do!
Originally Posted by dlibson
Good morning guys!
Good morning Dave!
So new bellowed up-pipes are in your future........
Originally Posted by MisterCMK
I know so!
IPR Gen 2 is a nice delete. The up pipe is nice stainless steel with a thick flange where it bolts to the manifold. Just saying. Lol
Yes they are Troy. And they will be the cheap *** Dorman ones on the IH ones.
Originally Posted by fordpower88
I wish the Dorman ones were around when I did mine. I would have gotten those.
I put the dorman ones on the excursion when I had the engine out for the oil pan replacement. I couldn't get the driver side to seal to the exhaust manifold. the manifold is pitted from rust so that might be the problem, probably should have changed that when I had it out. I haven't checked them this summer yet. I was letting some heat cycles work the bellows some to help them stretch to tighten the bolts to maybe get it to seal
I do think I am a bit low on brain cells so it will need to be addressed sometime before next spring I think but I don't believe I will worry about it before then.
