can you help?
Sorry it's been a while haven't been able todo anything with the truck till this week, so the fuel pressure is good right about 55 with KOEO, I pulled the codes and these are what showed,117-ect sensor signal voltage too low,122- tp sensor voltage to low, 126- map or bp signal values higher or lower than expected,112- act sensor voltage to low, 327- eve,pfe, or pet signal voltage to low,513- eca problem internal voltage test fail,553-tad or am2, solenoid circuit fail, 552 tab or am1 solenoid circuit fail,556 fuel pump relay primary circuit fail,558- evr solenoid circuit fail,565 canister purge solenoid circuit fail, so where should I start ? Would a bad pcm cause these ? Seems like quite a few things aren't getting the voltage they need. Any insight is greatly appreciated
on
chopped up from amateur radio or other accessories being installed? If so
I would go pull harnesses at a pick and pull. And while changing them out
super clean all connections. Dielectric grease is your friend. My $0.02
Terminals and battery are new, I'll check the grounds, as far as wiring being chopped up where would I be looking, it does have a CD player installed and I don't know who put it in or their skill level but If I had to guess I'd say amateur, is the wiring harness your referring to go to the radio ? Just checked ground off neg. battery terminal and it looks good.
FordCigarMan
29
06-26-2017 08:28 AM
Kallie
03-24-2007 02:43 PM
tstrickland
1983 - 2012 Ranger & B-Series
08-24-2001 09:35 PM
