Missing
Old Aug 29, 2014 | 05:07 PM
bill wilson's Avatar
bill wilson
Missing
Hey all. I've had my 97 one ton for a while and she's got 240 thousand miles on her. She's recently started to have a slight miss and white smoke. When I used to start it she smoked blue and ran fine. Now it's blue and white. Before it would miss cold and eventually run fine. I assumed it would e the valve cover gaskets being worn out and needing replaced. I have learned that being as old as they are, the connections will eventually give way and only make good connection when it is warm and has expanded to a point. I will replace these gaskets over the weekend. What other problems could be occurring besides this or a bad injector? I will pull then too and look at then while I've got it tore apart.
Old Aug 29, 2014 | 09:01 PM
ReBilld's Avatar
ReBilld
First place I'd look would be the UVCHs. Unplug each connector at the valve cover and check for burnt pins.
Old Aug 29, 2014 | 10:04 PM
fordpride's Avatar
fordpride
From what you are saying, it sounds like bad injectors
Silverhks
13
Jul 23, 2019 10:45 PM
bill wilson
Sep 7, 2014 09:45 AM
crzycrazycarl
Nov 12, 2010 12:17 AM
phatmanmike
Jan 18, 2008 09:15 PM
