1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 F250 Windshield Washer Pump Problem
Old 08-29-2014, 03:25 PM
Tdogg0413's Avatar
Tdogg0413
Tdogg0413 is offline
Hi All,
New to the 250, love the truck. Bought used from a dealer about 2.5 hrs away. Washers worked fine on the way home, but now can't get them to spray. I've put new nozzles in, and traced the tubes. I can hear the pump, and when I remove the tube down to just above the battery, I get a very weak trickle of washer fluid out. Assuming just need to remove battery to get access to the pump? Anyone have any experience / diagrams. Was thinking of getting a repair manual, Haynes vs. Chilton's? Thanks in Advance! Great site, looking forward to all the fun!
Old 08-29-2014, 04:32 PM
seville009's Avatar
seville009
seville009 is offline
Use a safety pin in the nozzle hole; that worked for me. Sometimes it's just the simple stuff.
Old 08-29-2014, 04:54 PM
Tdogg0413's Avatar
Tdogg0413
Thanks. I actually broke the nozzles removing them to do just that. They have been replaced. I removed all tubing down to near battery, and just barely get a trickle. Weak pump ithink. Just need to know how to replace the pump!
Old 08-30-2014, 08:40 AM
glsurratt's Avatar
glsurratt
glsurratt is offline
My washers quit a couple of weeks ago, and I decided to check the system when I read this thread.
I tried to pull the hose off one of the nozzles and snapped the fitting off inside the rubber "T".
SHAME ON FORD!! Why would anybody put a plastic nozzles in the middle of the hood of a truck right above the turbocharger that can run up to 1300 - 1500 degrees during normal operation.
There's no insulation blanket on the hood to provide any kind of protection. I suspect the nozzles melted during a heavy tow with my 21,000 lb fifth wheel in the mountains of West Virginia. Since then, they've become brittle and break when you touch them.
I'll be replacing both nozzles later this week.
Old 08-30-2014, 08:45 AM
seville009's Avatar
seville009
Don't have to remove anything when you use the pin; you just do it from the outside on top if the hood.
uofmgriz
10-16-2021 04:15 PM
thordehr
05-02-2019 01:27 PM
jclemons
01-27-2019 05:36 PM
DawnPatrol
08-22-2017 10:38 AM
Quick Reply: 2011 F250 Windshield Washer Pump Problem
