1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Lockable fuel door for 2015 F-350 Super Duty
Old 08-28-2014, 03:24 PM
billcard's Avatar
billcard
billcard is offline
Hi.
After scrutinizing the web and relevant forums for a lockable fuel door for my 2015 F-350 SD Powerstroke Diesel, it appeared that no one knew of a fuel door that would fit for sure.
I checked web stores that offered lockable fuel doors but they all indicated that the doors would only fit up to the 2014 trucks.
I checked with my dealer parts guy and he confirmed that the OEM fuel doors for the 2014 and 2015 are the same part numbers so I felt pretty safe in ordering the AMI door (I got mine in the "Brushed" appearance; part # 6058L).
Having installed mine, I can state that the AMI fuel doors will fit the 2015 F-350 Super Duty (assuming they're all the same size and have the same fittings but only differ in appearance; e.g., brushed, chrome, black, etc.).
HOWEVER, there are some caveats. If I had it to do all over again, along with following the enclosed instruction sheet step-by-step, I'd:
1. Cut off the studs half way. They're waaaaaaaaay too long and, at that length, some of the hardware didn't fit.
2. Drill out the rubber-stopper holes (as instructed in the instructions) but then angle the driver upward on the top hole and downward on the bottom hole to make the holes slightly elliptical instead of round. (Note: If the studs are cut off halfway as suggested above, this step might not be needed.)
3. Toss the gigantic flat washers that are supplied as none of them will fit anywhere except on the top-left stud. Standard-sized flat washers work fine.
Note: I just clipped the plastic strap (for the green twist-cap) off since I don't leave the fuel door while pumping so the cap will be with me at all times.
Other than that, it is a simple replacement of the OEM door and can easily be done in less than half an hour, including the additions I listed above.
I've placed some pics of the door mounted on my 2015 F-350 Super Duty on DropBox at https://www.dropbox.com/sh/qbs47s5c2...U-Ah6KMOa?dl=0
Hope that helps you and others.
bc
Old 09-06-2014, 05:03 PM
Detailjohn's Avatar
Detailjohn
Detailjohn is offline
Looks great
I may do the same to my 15 f250, where did u order door?
Thanks
John
Old 09-07-2014, 06:29 PM
billcard's Avatar
billcard
billcard is offline
I got mine here:
http://www.summitracing.com/parts/as...y/submodel/xlt
But you can find them at a lot of places on the web.
Good luck!
Old 09-07-2014, 07:05 PM
Detailjohn's Avatar
Detailjohn
Thanks
Retiredout
2017+ Super Duty
36
01-29-2019 12:26 PM
russtman
2017+ Super Duty
08-15-2018 10:44 AM
rbsev
2017+ Super Duty
04-30-2017 05:24 AM
troverman
02-27-2015 05:51 PM
Solid By Design
09-29-2008 10:46 PM
Quick Reply: Lockable fuel door for 2015 F-350 Super Duty
