speakers problem
Old Aug 27, 2014 | 10:56 AM
mr.noodi's Avatar
mr.noodi
speakers problem
My 2000 limited EX rear speakers is not working like it should some times it shut completely off and some times I can hear a noise like ( shhh sh sh tt sh ) but when I crank the volume up it works fine and the distortion noise just from the right third row seat and it is little noise .
Now I installed new speakers but same problem no change .
And I took all the interior out for sound proofing the EX , I checked all the wiring and connection with no luck to find any issues.
Also the module in the console is fine and the head unit is after market 2din with gps
Any ideas?
Old Aug 27, 2014 | 01:30 PM
mtnsammy's Avatar
mtnsammy
We installed a Pioneer in our rig last year when the truck radio died outside New Mexico on the way to Kansas. Real quiet and boring with no tunes. I had problems with eating CD's and a parasitic power draw. After changing the radio the sound was 10 times better with factory speakers still there and we found there were back speaker we never heard. The only down side was losing the mid stereo controls. Our dogs are not allowed to play with the radio anyways so we do not care about losing the mid control panel.
Old Aug 27, 2014 | 01:33 PM
mr.noodi's Avatar
mr.noodi
I do have a new head unit and new speakers but same noise issue
Old Aug 28, 2014 | 12:01 AM
superdave02f552's Avatar
superdave02f552
Poor speaker ground try adding a temp chassis grind to see if that helps
Old Aug 28, 2014 | 01:07 AM
Technologiq's Avatar
Technologiq
Pop the cupholder on the rear of the center console and look inside. You may have loose wires or corrosion that has caused the unit inside to fail. This unit is what provides sound to the rear speakers.
Old Aug 28, 2014 | 08:16 PM
mr.noodi's Avatar
mr.noodi
I cleaned the corrosion on the connector and it worked but still There a little bit of noise.
00t444e
Jul 2, 2018 08:49 AM
ars_lurker
Jan 3, 2015 06:53 AM
01f550
Nov 30, 2013 07:54 PM
Brown91
Mar 10, 2011 02:41 PM
1967fordranger
Aug 12, 2002 05:56 PM
