No power to cab. 1983 F-150
Hello everyone. I have a 1983 F-150 with the 300 inline. I currently have no power to the cab. No headlight, dash or radio. Any help or advise will be appreciated. The previous owner replaced the starter and the seolonied. I would upload pictures but not sure how to.
The ground is hooked to the engine. The hot wire goes to the starter solioniod. Then out the other side to the starter. I have one wire that runs to the solioniod. I can cross the solioniod and the engine will turn over, just no power to the cab. When I turn the key I don't get any light or guage that works.
Check your grounds, I had the same issue and both my ground cables were culprits. Also pull up a diagram for the solenoid to make sure its wired properly. Would also help to check, then recheck your fuses after each start. I know my overhead cab light was fixed with the simple change of a fuse.
Fixorforme
34
11-20-2017 09:30 PM
ford 400 outlaw
09-11-2015 03:01 PM
ctvanover
03-12-2013 10:32 PM
burninrubber2416
10-05-2008 12:43 AM
