Surging while braking at slow speeds
Old Apr 25, 2002 | 05:29 PM
whistler's Avatar
whistler
I have a problem that I need some advice on.
While I am braking at low speeds (1-10 mph) I feel a surging in the truck. The brake pedal itself does not pulse. It more feels like the brakes are catching then letting go, then catching then letting go, etc. Like I said, I only feel this at very low speeds while braking.
I have a few ideas of what could be happening, but I am unsure how to diagnose them correctly.
I have had some problems with the rear brakes. Possible warpage? How do I go about finding out if the drums are warped?
Front brakes. I don't know much about disk brakes.
Master cylinder or power brake booster? I would have no idea how to diagnose problems with these.
If you can help me with any of these or have any additional ideas I would be very appreciative.
Thanks,
Whistler
Old Apr 25, 2002 | 07:17 PM
Redneckerson's Avatar
Redneckerson
I would say either the disc's or drums are warped. The only way to tell is to attach a magnetic base and dial indicator and verify the run out. When you find which ones you can replace the culprits with new ones or if it's not to bad have them turned out. From prior experience after they have warped once they tend to be chronic offenders. Regards
Old Apr 26, 2002 | 07:54 AM
whistler's Avatar
whistler
Thanks,
I'll have those checked out. I certainly don't have the tools for that.
Whistler
Old Apr 26, 2002 | 09:00 AM
mickelsons's Avatar
mickelsons
What kind of rig are you talking about? I bet it is a F-150, and if that is the case I would put my money on the front rotors being warped.
Old Apr 26, 2002 | 11:51 AM
whistler's Avatar
whistler
Mickelson,
It is a 92 F-150. I kind of suspected that it might be the front brakes. The rear brakes were worked on not that long ago.
Thanks,I'll see what I can find this weekend.
Whistler
Old Apr 26, 2002 | 02:53 PM
gasman6674's Avatar
gasman6674
Old Apr 26, 2002 | 03:07 PM
gasman6674's Avatar
gasman6674
Post Surging while braking at slow speeds
If the rotors are OEM replace them and save your self some hassle.
I had the same problem on my 92 F150 turning didnt help, put new ones on prolem solved.
Regards
