What trans do i have? 85 E150 6 cyl 3 speed overdrive manual
Hello new to the site here. I have a 1985 E150 4.9 inline 6 with a 4 speed manual (3 speed with overdrive?) The transmission is stuck in first gear. The problem started out that it was hard to put in first gear and reverse when the truck was running. It would go in eventually but with some grinding and force. If i shut the van off it would shift thru all gears effortlessly. Now the van is stuck in first gear. I've been able to get under there and manually knock it in and out of gear with a tap of a hammer. Ive checked the master for air(seems fine) and the slave is working properly. The previous owner said they replaced the clutch I'm guessing about 15k ago. Im trying to avoid taking it into a shop because i just don't trust em. Im pretty mechnically inclined but i just don't have any experience with transmissions/clutches. Thanks for your time and help
1985E150pdx
08-28-2014 12:56 PM
300I6VAN85
05-04-2006 09:50 AM
williape
06-28-2004 01:27 PM
78f250lj
01-22-2003 06:57 PM
