Trouble while towing.....limped it home!!
TIUSER,
Sorry about your engine problem . Whenever a V10 develops an engine problem we all V10 owners are concerned about it .Would you mind providing some more info , like are you the original owner (or know the maintenance history since new) ,how many miles on the odometer, what grade engine oil and what brand oil filter and oil change intervals used .
Wish you all the best,
Second owner, bought from original owner @ 108,000 miles 10 months ago. Don't know the exact maintanence history, but was told they had it serviced with the other vehicles in their fleet by their duty mechanic. They owned a landscape company and had a fulltime mechanic, this was the owner's wife's kid hauler, aka soccer mom truck. The truck was checked out by my mechanic and it was given clean bill of health, he said the truck looks like it has been maintained. The truck ran great until this incident.
The only thing that could bend valves is either the valve stuck in the guide and the piston hit it, or the valve spring is weak or broken and the piston hit it because of valve float.
While the engine is apart, take pictures of the pistons on these cylinders where there were "bent valves" - remember, we're just going on the mechanic's say-so at this point, or even second-hand info if you're talking to the owner of the shop and one of his employees is doing the job.
Take pics of the valves too, something sounds very strange if it was running so well and suddenly took a poop
As far as I know, there was no piston contact, but I will know more this week, because it should be done.
The exhaust studs on #5 side (passenger side) were repaired 10 months ago and there were 5 bad at that time. There were 5 bad studs this time too, not sure if they were the same studs or not, per my mechanic the wrong gasket was used in the previous repair. All totaled between both sides, 10 exhaust studs needed replacement during the head repair. Contributing factor to bent valves???
I have had the truck back for about two weeks and put about 400 miles on it with no problems so far.
#29
#30
That would be my bet. I had a 4.6 one time loose a vacuum line under heavy throttle. 10 seconds of hard pinging before I got out of it and it had broken rings on 3 cylinders.
Floating a valve with over rev isn't a problem normally on the modular engines. You can usually go well past anything that could be considered a normal RPM for awhile without any damage.
