Tried it all!!!
Old Aug 24, 2014 | 01:51 PM
  #31
trozei's Avatar
trozei
You likely only have a bad valve in the cylinder head. That's a cheaper fix than a crate engine.
Old Aug 24, 2014 | 01:59 PM
  #32
351Cleveland C4's Avatar
351Cleveland C4
Was that reading with the throttle open or closed?
And 2x what trozei has said. There's cheaper ways than a new motor, unless that's what you want to do....
Old Aug 24, 2014 | 02:00 PM
  #33
Alleycat3677's Avatar
Alleycat3677
No. At idle withe the truck running. I don't have a clue what I want. A crate would be nice but costly. Time will tell.
Old Aug 24, 2014 | 02:02 PM
  #34
351Cleveland C4
At idle, all readings will be low, you have to see what they read at full volume. This means removing all the plugs, blocking the throttle wide open, and cranking the engine a few rounds on each cylinder. That will give you your true results.
Old Aug 24, 2014 | 02:04 PM
  #35
Alleycat3677
Thanks. Don't know when I can do it but I'll let you know as soon as I do.
Old Aug 24, 2014 | 02:07 PM
  #36
351Cleveland C4
Ok, my time estimate would be about 30-45 minutes to do it realistically. It could be done faster if your fast. But no need to rush if you don't have to.
Old Aug 24, 2014 | 02:14 PM
  #37
trozei's Avatar
trozei
Do a wet and a dry test on all cylinders. A dry test is as you'd normally do and a wet test is done by pouring a bit of oil down the spark plug hole to seal the rings. If the number drastically changes, you have an issue with your rings.
Also, a vacuum test can indicate if your valves are good or bad. At idle, if the needle is jumping 1-2 inches, you have a bad ignition somewhere. If it jumps around 4", you have bad valves. You want the needle to be steady.
Old Aug 24, 2014 | 02:17 PM
  #38
351Cleveland C4
^ what he said!
Old Aug 24, 2014 | 02:20 PM
  #39
trozei's Avatar
trozei
A vacuum test is the OBDI-II scanner of the carburetor world. The only thing that beats it is a Sun machine.
Old Aug 24, 2014 | 07:59 PM
  #40
trozei's Avatar
trozei
Originally Posted by Alleycat3677
Yes it is. Dizzy is new. Checked advance when I installed it a couple weeks ago.
How did you check the advance?
Old Aug 24, 2014 | 08:02 PM
  #41
Alleycat3677
Timing light. At idle it is at 8 when I throttle it it advanced. May bump the timing up a bit. Wish I knew how to put photos up. I use my phone and don't have a computer. I just put roll on bed liner on and it looks great.
Old Aug 24, 2014 | 08:35 PM
  #42
351Cleveland C4
Advance your timing to 12 or 14 and see what that does.
Old Aug 24, 2014 | 08:38 PM
  #43
Alleycat3677
Really? That high? Fact. setting is 6. Okay I work a 24 hr. shift at the firehouse tomorrow so I can't until tues. Thanks guys
Old Aug 24, 2014 | 09:46 PM
  #44
351Cleveland C4
Yes that high. You will notice a huge improvement in starting, power, and some economy gain. The motor will have a lot more snap to it. Throttle response will be tons better.
Old Aug 24, 2014 | 10:19 PM
  #45
trozei's Avatar
trozei
Take your vacuum hose (or hoses) that is attached to the distributor and suck on it from the opposite end. If you can breathe through it like a straw, your vacuum advance is bad. If there's a fighting suction, the advance is good.
