2 Speed Axle
Old Aug 22, 2014 | 08:35 AM
Bubba-88's Avatar
Bubba-88
2 Speed Axle
Can the 2 speed axle be placed in high gear permanently?The vacuum pod is still attached but there are no vacuum line attached. I only use my F6 Dump for pleasure so I don't need the lower gear.
Old Aug 22, 2014 | 12:03 PM
pweng1's Avatar
pweng1
permanantly in high
Mine is missing the diapham assembly and is wired over to high which is the default i believe. The lever is wired closer to the jackpot for high. Just a warning though it wont seem like much different because of rear ratio my 1st ( Granny) gear is like 6 ft. before you shift.
Old Aug 22, 2014 | 02:04 PM
raytasch's Avatar
raytasch
Believe Nothing
When I first drove one of these old trucks with the two speed, I was cautioned to always have it in low range when I went into a tight spot where I might need all the power I could get. That said, for an unloaded truck, lock it in high range and enjoy it.
Old Aug 22, 2014 | 02:40 PM
Bubba-88's Avatar
Bubba-88
Thanks for all the help. I'll let you know how it goes.
Boxhead
1947 and Older Ford Trucks
Nov 18, 2018 01:03 AM
hulaman
Oct 8, 2012 09:49 PM
Ty_Yota
Nov 28, 2009 04:40 PM
Mr. Thomas
20
Oct 30, 2007 07:53 PM
geoaigel
Nov 2, 2002 08:40 AM
