HELP...Bad Truck, Bad
Old Apr 23, 2002 | 09:27 PM
workjunkie's Avatar
workjunkie
Howdy,
I'm new to FTE but have found it very interesting so far.
Anyway, I have a 1988 F150 with the 300 straight 6 and the bugger will not start. I have replaced the fuel pump relay, the eec relay, the ignition switch, and by-passed the inertia switch. Have also removed some questionable fuse links and rewired some nasty looking wires. Still nothing. If I jump over on the power wire to the eec relay, I can get the fuel pumps to run, but she won't start. And no matter what I do, I can't get the ignition wire to pull in the contactor in the eec relay.
Would greatly appreciate any ideas anyone might be able to conjure up on the subject. Thanks, Workjunkie
Old Apr 24, 2002 | 04:09 AM
kmichaelb's Avatar
kmichaelb
[updated:LAST EDITED ON 24-Apr-02 AT 05:13 AM (EST)]It might be a plugged catalytic converter. Unbolt the flange at the front of the converter and see if it will start. kmichaelb
Old Apr 24, 2002 | 05:45 AM
rabidranger's Avatar
rabidranger
I take it the engine cranks? If so pull a spark plug and ground it out to see if you have spark, while you have a plug out, look at the insulator and see what condition it is in.
Old Apr 24, 2002 | 09:32 AM
DrFord's Avatar
DrFord
how long has it been since it last ran?. did one morning it just all of a sudden decide that id didn't want to start. didd you do any modifications before this happened.
check the distributer and make sure that it is tight. it might have come loose and twisted and therefore thrown your timing off. I know that you can't exactly check the timing if the engine won't start, but maybe that will lead you somewhere.
Old Apr 25, 2002 | 12:28 PM
winfordr's Avatar
winfordr
Workjunkie:
Because you said "I can't get the ignition wire to pull in the contactor in the eec relay.", you can eliminate the other possibilities until you solve this one.
I would get some small jumper wires and force the relay to activate. You may have to connect both the source and ground connectors of the relay coil. It could have a bad ground. Leave it enabled, then try starting. Do you have a tachometer? If so you can tell if you are getting ignition by watching it while you crank the engine.
What you do next depends on what these results are.
Winford
Old Apr 28, 2002 | 01:15 PM
msj6819's Avatar
msj6819
Post HELP...Bad Truck, Bad
A friend of mine bought a 89 F150 with a 300 in it that had been wrecked a few years ago that wouldn't start so he got it for next to nothing. There was some sort of emergency switch, activated by a hard impact, that disabled the truck. The purpose was to prevent gas from running during a serious accident. His dad switched, replaced, I can't remember what he had to do, but the truck started right up. Sorry I'm really vague but it was probably six years ago, maybe this will point you in the right direction.
Old Apr 28, 2002 | 02:12 PM
pancake's Avatar
pancake
you are talking about the fuel pump inertia switch and he said that he by passed the switch and it didnt help
Old Apr 28, 2002 | 03:02 PM
thomasr's Avatar
thomasr
