Would like some advise from Mark
on
I am in the process of changing out the rms in my 03 v10. I got the drive shafts off and unbolted the transfer case. I wiggled it out and got to enjoy a dribble of trans fluid on my left shirt pocket. The gasket between the trans and trans was trashed.
My question is, looking at the picture of the rear of he transmission, should their be a pool of fluid behind the "dam" at the bottom of this opening?
I included a shot of the area in front of this that looks like it has been wet for a while.
One more thing. The connector shown from the passenger side is wet inside with trans fluid also.
Do I need to do anything while I have these out???
I have gotten a OSS code in the past. Wonder if it has something to do with being splashed with transmission fluid
Hey, does anyone know of a good place to get a new gasket?
Thanks.
Thanks.
I usually give a lot of leeway when it comes to guys talking off-topic and getting a little pissy with each other because that's life, but my patience for BS is at an all time low right now.
I've cleaned the thread from extraneous BS and left it all tech. Please, let's keep it that way.
Thanks guys.
Stewart
Thanks guys.
Stewart
Why not let it be I read what was wrote befor you deleted it that guy is a$$ and pisses about 95% of ppl off evey time. Why do yall insist to give ppl like that privileges to respond with answers like that. That guy gives answers like that all the time something needs to be done. And yall cant expect normal ppl not to respond and this guy mark responded nice now as for some others are more intensive. Deleting things doesn't make it go away every one knows about him and his idiotic responses
on
on
You are getting sleepy.... You will follow your momma's advice..... You will refrain from saying anything if you can't say something kind.... You will send every FTE member $1 for every intolerant comment you make towards another person's post....you will wake up and be happy go lucky and not expect everyone to do things the way you do...... 3...2...1...open your eyes. Have a great life!
