NP435??
Old Aug 17, 2014 | 02:11 PM
ArmyCook's Avatar
ArmyCook
NP435??
Okay, Fiancé's uncle has this old F600 sitting at the farm and he said I could have the four speed out of it. Also offered me the five speed out of the old F
700 sitting out there too. I believe that the 4 speed is a NP435 and that the 5 speed is a Clark 282v. Would like to swap out the C6 in my 77 F250 for a manual and would like to verify that the 4 is indeed a New Process. Unfortunately there is no data plate on the truck so it's a visual comparison. OR, would the Clark be a viable option. Was told that the F600 had the 330 in it originally. No idea about the F700. If I swapped in the NP435 what transmission parts would I have to change besides the bellhousing? I believe I can get the clutch pedal/linkages/slave cylinder from the donor truck.
Transmission in truck
Googled Pic of NP435
Old Aug 17, 2014 | 02:24 PM
ArmyCook's Avatar
ArmyCook
Truck with the 4-speed
Truck with the 5-speed
Old Aug 17, 2014 | 02:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Left: New Process 435 shift lever retainer cap (B8T-7220-D) has two notches, is retained to the shift tower with two pins.
To remove this cap, it must be pressed down by hand and held down while turning it to remove it.
Some people are unaware, use pliers or channel locks to remove it...which tears out one or both of the notches. Not Pleasant!
Right: Warner T-18 shift lever retainer cap (8MTH-7220) threads off/on.
Old Aug 17, 2014 | 02:36 PM
ArmyCook's Avatar
ArmyCook
Thanks NumberDummy. I'll keep that in mind when I pull that tranny out of the truck.
Old Aug 17, 2014 | 02:47 PM
NumberDummy
1973/79: Only C Series Tilt Cabs have a hydraulic clutch.
None of the F500/750 clutch linkage parts will work on an F100/350.
The F500/750 NP435 input shaft is larger in diameter than the one for F100/350's.
Old Aug 17, 2014 | 03:03 PM
ArmyCook's Avatar
ArmyCook
ND, I can't tell by the diagram but would it be possible to change out the input shaft with one of the correct size or would all of the internals be affected?
Old Aug 17, 2014 | 03:13 PM
NumberDummy
The entire trans has to be disassembled to remove the input shaft, and where will you find the correct input shaft and all the clutch linkage and pedals for a 1977 F250?
1973/79 F100/350: There are TWENTY TWO different brake pedals, NINETEEN different power brake boosters, SEVENTEEN different master cylinders and SEVEN different clutch pedals, I kid you not!
The brake and clutch pedals you use must match the brake booster the truck has now.
IMO: Forget it, you will be opening a HUGE can of worms while attempting to make this swap.
Old Aug 17, 2014 | 03:21 PM
ArmyCook's Avatar
ArmyCook
Well damn. Guess if I really want a 4-speed I need to just find a truck that's already got it and just swap my engine over to it.
Old Aug 17, 2014 | 03:43 PM
lafermedavid's Avatar
lafermedavid
Id shoot to restore the f600 nice dump.what a gem
Old Aug 17, 2014 | 03:58 PM
ArmyCook's Avatar
ArmyCook
I have thought about it, and it is in much better shape than expected. But not sure where to start on it. I guess find an engine for it. Most of the engine bits are sitting in the cab.
BTW, if someone is interested in buying either of these trucks, the owner will probably sell them for the right price. Next weekend I'm going back out there to swap out the crappy bed on my pickup for the somewhat better bed he has. I'll see about getting some more pics of the trucks.
gogreenwave
Nov 1, 2014 10:35 PM
D & D
Oct 20, 2013 07:03 PM
Queueball
Feb 1, 2013 02:01 PM
policeunit1955
Jan 15, 2013 06:29 PM
rb7604
22
Oct 27, 2008 03:53 PM
