Low Fuel Pressure w/ Blue spring
Glowshift gauge is reading 59 running and drops to 45 at not even WOT. KOEO it reads 45 steady. I have had some bad luck with glowshift sending units about to be on my 3rd now as it may be bad, it was previously bouncing around at 70-80 but now its reading low and a bit jumpy..
Any way to see if my HFCM is getting weak or is it just my sender again
Blue spring upgrade has been in for a few months, fuel filters have 3000km on them. When the sender was new, it read 63 psi at idle and WOT never below 55....
Got them from the dealership themselves. All OEM
Update: Got mad because i'm broke and really hate the fact that this may be the 3rd fuel pressure sender dead from glowshift.. Went outside, drained the HFCM, checked for debris in the top fuel housing, took apart the test port(Where the blue spring goes) made sure everything was a-ok. Checked my line to my fuel pressure sender mounted near the rad, checked for debris, checked for something maybe in the little hole in the sender and found not a damn thing. Put it all together and went to drive the ******** off it to see if it really is falling below 45. As soon as i pulled out of the driveway it pegged to 100 and i just knew she was dead. 3rd sender dead, even remotely mounted it this time and went all of 2 weeks without issue. How the h*** am i to justify spending 30$ every 2 weeks on new sending units?
On the bright side i guess it's not my HFCM yet.. maybe i could just splurge on a sinister regulated return or fuel system and set my own pressure. Would that be a fix to this junk?
Better yet, is there a sender unit that would work with the glowshift gauges?
I replaced them yes, only went with glowshift because of the price, set of 3 gauges and all hardware for 200$ on a monthly deal is hard to beat.. but not having something work right just drives me absolutely nuts. It's obvious my fuel pressure should be okay, but the jumpy fuel pressure gauge would bother anyone i bet. I don't want to just remove it, because my pillar would have a hole and look silly.. needs 3 gauges. Sounds like you've had some trouble with isspro also.. how long do fuel pressure senders usually last for you?
The gauge was DOA when I bought it from a vendor, Isspro replaced for free, the needle never homed to zero correctly right out of the box. First sending unit made it about a year, failed with diesel through the connector. Second one might not have actually been bad, might have just been air in the line, but I called and Isspro mailed me a new one before I identified/solved the air issue. Each time I mailed them back the old part.
They're out of office right now so i'll update tomorrow. I'm sure they'll have me test it, not sure how though.
Maybe i should get replacements for both? then i'd have an extra on hand to keep changing them out when they die. Friggin GS
I got one of these adaptors to remotely mount my FP sensor near the firewall away from engine vibration.
Driven Diesel 6.0L Fuel Pressure Adapter
My spatechique dual-gauge and sensor have been working for 18 months with no issues..
Your fuel psi sender is mounted near the radiator? Why?
Sounds like the sender is bad again...see if Glow**** will replace it and then relocate it closer to firewall or driver fender. It may be getting too hot.
It's really starting to sound like they make crap.
Amazon Review:
Amazon.com: Customer Reviews: GlowShift Tinted 30 PSI Boost / Vacuum Gauge
GlowShift Gauges Store Policies and Warranty Terms
< Snip >
ONE YEAR NON-TRANSFERRABLE LIMITED WARRANTY AND DISCLAIMER
GlowShift Gauges, LLC ("GlowShift") warrants to the original retail consumer purchaser, and not any other purchaser or subsequent owner, that this Product will be free from defects in material or workmanship for a period of one (1) year from the purchase date.
< Snip >
BUT THERE IS MORE TO IT THAN JUST THAT.
Sean
Update to the sender issue, just sent a message today, worked late and out of service yesterday. I really agree that they sell cheaper parts, but i dont know how they'd be making any money with 2 week fuel pressure senders with warranty
Hopefully get the OK for a free new one or two today, and if those end up dieing i'm just going to get a new fuel pressure unit from someone else, i have trans temp and pyro from glowshift and those haven't had a hiccup since i got them put in 2 months ago
I've had my Autometer sensor in for two years and it's been perfect the whole time. It's mounted directly in the fuel test port. There is no vibration on this engine that will hurt a quality sensor, and Autometer are made for NASCAR use (you see the exact same guage I have in every in-car shot) where the vibration and heat are extreme. I've been using autometer for close to 25 years and have yet to experience a gauge failure, both mechanical and electric gauges. In fact I saw a race car I built probably 25 years ago a few weeks ago, it still has the same AutoGage (cheap Autometer brand) gauges I installed when I first built the car, still in there, working and accurate.
Just sayin...
Brian
Just sayin...
Brian
