DIESELSITE Fuel Filter / Water Separator
I just installed the DIESELSITE Fuel Filter / Water Separator on my 2012 F350 DRW. I spoke to the people at DIESELSITE and they said there was no reason to build a shroud around them. What are the thoughts on that, and if you did enclose them what did you use?
I have not yet installed a shield on mine, but I don't drive off-road or on lots of gravel roads. I would be concerned about having rocks thrown from the front tire into the bowl, potentially causing a crack, or knocking off a petcock. They are made from the same impact resistant material that safety glasses are made from though, so it's not exactly fragile. My idea to put a shroud on them though was thin gauge aluminum or sheet metal mounted directly in front of the unit just to deflect whatever flies off of the tire.
Cjbratvold
05-14-2019 09:48 AM
whalebus2112
07-29-2012 01:01 AM
ExpySport
12-01-2008 08:40 PM
twotonestepside
01-26-2008 10:00 PM
