E4OD, anyway to bypass VSS switch on differential?
You will need to calibrate the PSOM to no translation of the input VSS signal.
In other words:
PSOM conversion constant = 1.0
You will also have change the gear going into the early tail housing and maybe the driver gear also to get the speedometer to read right for your gear ratio and tire size.
This is how it is done by Ford on the 1992-1997 F53 chassis.
Edit:
You would use the same two gears that was used on the 1989-1991 trucks with the same tire size and rear end gears as with the conversion constant at 1.0 you would have the same information going to the computer that they did with the 1989-1991 trucks.
If the output shaft has the drive gear on it you could use an early tail housing.
In other words:
Edit:
In other words:
Edit:
I don't know how well that would work. Wouldn't you also need the wiring to EEC? Also the VSS on rear is used with the RABS system so you would have the antilock light on constantly. I would go with a cleaning and a close visual inspection of VSS first. Then reinstall it and block up rear wheels and check for voltage from the VSS as wheels are turning, BE SURE TO CHOCK THE FRONT WHEELS BEFORE DOING THIS! I never want to feel responsible for a FTE member getting run over by his own truck. I don't recall how many volts are produced but it's not much. A corroded or damaged wire could make a big difference. Might test at the VSS as well as the test connection under the hood.
The above text was only for BruteFord.
The wiring to the PSOM would only come from the tail shaft and the RABS may not work because the frequency would be to low.
The 1992-1997 F53 chassis do not have the RABS. The wiring is ran a little different as the wires are split and go right to the PCM Computer, Speed Control module and the PSOM. The PSOM on the F53 does not output to anything else except the speedometer head and the odometer. But I think the output as described above would still output to the Speed Control and the PCM Computer OK.
See diagram below for the F53:
In other words:
Edit:
In other words:
Edit:
There is no power signal on the mile reader and the hole system just quit no speedo bounce.
If you LCD odometer does not have a mileage readout when the key is turned on and the needle does not go below zero and hit the peg when the key is turned on you have a problem with the PSOM and not the rear end or wiring from the rear end to the PSOM.
You most likely have a bad fuse (8 or 18) in the IP fuse panel.
As you may know the 1989 - 1991 trucks with the E4OD the speed signal ran from the transmission right to the computer. The same as the 1992-1997 F53 does. The speedometer was cable driven in the 1989 - 1991 trucks.
I will go turn the key to see what happens at the dash. Thanks.
#29
PSOM (Programmable Speedometer/Odometer Module): A module that processes vehicle speed information for use in various electronic systems. The PSOM can be programmed to accommodate various tire and axle combinations.
The PSOM:
The PSOM:
