That was the ingnition control module right? black
Yes that is the ICM and your truck takes the Black one.
The wire from the SPOUT shorting bar going to the computer must be either shorted to ground or shorted to a power wire.
we have spark when we pull the spout out and it starts with starter fluid (no fuel ) the pumps work when you bypass them I will get more info for you
Well, I hope your tech will be able to help onsite, but I'm still stuck on page 1.
The starter fluid test certainly proves the no fuel theory, but did it start with, or without the SPOUT?
Did you try the starter fluid test both with and without the SPOUT installed?
Given that you have OBDII diagnostics, how did you "bypass" the fuel pumps? OBDI has a test point on the connector that you can ground to activate the fuel pump relay and test the relay/pumps. I don't think that was available in OBDII, but of course on a CA spec vehicle, anything seems possible?
Found what looks to be a definitive list on OBDI vs OBDII.
Looks like you have discovered it is not a simple module failure. That finned module is actually a remote mounted TFI ignition module. There is a pretty good discussion of that component here;
