Help, What's causing this steering issue?
Old Aug 16, 2014 | 02:50 PM
pgguru's Avatar
pgguru
After replacing both needle bearings in the spring I marked the axles and drove for a week and they did not move
Unless it had moved both axles to the same point
Old Aug 16, 2014 | 09:23 PM
Xcelor8's Avatar
Xcelor8
Too hot today to troubleshoot tomorrow will be nicer, and the wife had different ideas.... I have the warn lockouts on, I'm certain they were free, but I checked them and I did push the button for 4x4 (without hubs being locked) and that didn't seem to change anything. We were driving it today without issues.
Old Aug 16, 2014 | 10:43 PM
EXv10's Avatar
EXv10
But they can move if there is too much friction in the hub or the needle bearings and when one axle moves with a binding U-joint it is a recipe for the dreaded steering wheel wobble.
Old Aug 19, 2014 | 05:20 PM
robert_l_ross's Avatar
robert_l_ross
Originally Posted by mecdac
At least it's not this bad....
Nothing a set of spring shackles couldn't fix.
Old Aug 19, 2014 | 09:22 PM
Bigpipes 35's Avatar
Bigpipes 35
Or a rear sway bar...
Old Aug 19, 2014 | 10:46 PM
mecdac's Avatar
mecdac
You are both wrong!
Redhead steering box.
Drama Eagle
Old Aug 19, 2014 | 11:07 PM
william_04_x's Avatar
william_04_x
You guys are way off base. That car has a transmission problem. First, reverse, and park are all engaged at the same time!
Old Aug 20, 2014 | 09:12 AM
Snowseeker's Avatar
Snowseeker
First thing I would do is rotate the tires.
Old Aug 20, 2014 | 09:20 AM
1 Excursion camper's Avatar
1 Excursion camper
Why? everytime you drive the tires rotate!
Old Aug 20, 2014 | 08:54 PM
Snowseeker's Avatar
Snowseeker
To get the worn spots out of synch, everyone knows all the tires turn equally all the time.
Old Aug 20, 2014 | 09:08 PM
william_04_x
Going straight, for a short distance, maybe.
Old Aug 21, 2014 | 09:24 AM
Snowseeker's Avatar
Snowseeker
I forgot the smiley for sarcasm.
The actual tire rotation I meant was the front wheels to the back opposite corners and the rear tires strait forward to the front.
Old Aug 21, 2014 | 09:42 AM
  #28
mecdac's Avatar
mecdac
Old Oct 22, 2014 | 09:31 PM
  #29
john72ss's Avatar
john72ss
steering wheel shimmys back and forth?
Originally Posted by EXv10
Mine was u-joints and I started a very long thread on it 2 years ago; "steering wheel jerks back and forth".
I have this same problem with my sons 2002 2 wheel drive, so it cant be the u joint! cant feel any shaking from the front end, just the steering wheel but disappears when I get past 30 mph, most noticable at 20 to 30 mph!
Old Oct 23, 2014 | 09:51 AM
  #30
DSMMH's Avatar
DSMMH
I have been chasing my X steering problem for years. Adjusted OEM steering box. A little better. Installed Landyot Radius rods and Firestone Air Bags. No change. Replaced steering box with Redhead box. A little better. Just replaced entire front end: MOOG Ball joints, control arm, tie rod, adjusters and Timkin hubs. Problem solved. Should have done this 5 years ago. The previous adjustments and parts were just expensive "band aids".
Ed
