If the next Super Duty had the same cab as the new F150, would you approve?
#62
#63
#66
I think Ford realizes that it has been a strength for them to have two different cabs in the F-Series line. I would be surprised if they went back. Let GM and Dodge cheap out and use the same cab. Ford is #1 for a reason.
#67
Ford just widened the F150. I suspect this is to allow cab sharing. (One Ford) The door panels are the main difference in hip width between a SD & F150. On the SD's, your Thigh sits below the armrest hump on the door. The F150 has the hump next to your thigh (It protrudes lower). Simple fix for Ford to get more width. The 2015 F150 cabs are much larger overall than the SD's. I always hated the cramped Super Duty cabs in my tow trucks.
#68
As the original poster of the question on the table in this thread, I'm just checking back in (to say I told ya so) now that the recently leaked image of the 2017 model year (not 2016) F-Super Duty redesign has revealed, fairly obviously, that my prediction of common core cab sharing between the F-150 and F-Super Duty light truck series has indeed come to pass.
It also appears that Ford successfully faked out quite a few people, including professional automotive journalists, with the Mega Cab looking disguises that were merely fairings tacked onto the end of the cab and suspended over the bed.
I suspect that the front clip on the Super Duty version of the common cab design will endure a mixed reaction, and might get some design tweaks sooner than the typical 5 to 6 year front clip refresh cycle. But the cab is likely here to stay for at least a decade, barring any structural or performance faults found in the field, as the end users multiply exponentially with each passing sales year.
#69
The new F150 cabs are almost the same width, but much more leg room than the Current SD.
#70
Almost is the key word here. Almost isn't equal. I want the extra width of the current SD. I would have liked the cab on my 06 F150 more if it would have been as wide as the current SD. More shoulder room is desirable in the northern half of the country in the winter, especially on work trucks. If I wanted a narrower cab like the F150 GM, Dodge, and Toyota would be considered when making a purchase.
#71
#72
Adam
#73
#74
