Grille Question??
Old Aug 15, 2014 | 09:02 PM
gangstakr's Avatar
gangstakr
Originally Posted by crazed87bronco
^ now that's a grille. mine will look as beautiful as that when the day comes for my order from you right
Are you saving all your money for the grille? Start now, turn in aluminum can's bottles, steel and any other recyclable items. Take out a second or third mortgage on the house. Sell everything that's not bolted down, then call me.
I hope to have a 65 grille soon, when I do I'll keep it for you until your ready regardless of how long it takes. You do get first dibs.
Old Aug 15, 2014 | 09:14 PM
gangstakr's Avatar
gangstakr
Originally Posted by daveengelson
Yes, gangstakr does a great job on reconditioning the grille, keeping in mind there's a significant different process between a polished vs anodized grille; unfortunately, don't find many platters who anodize any more, and not advisable to chrome the grille.
I've run into a couple of shops that will anodize however they have small vats so it's necessary to double dip, meaning doing half then the other half. It does leave a line not real noticeable but I can see it.
Thanks to the EPA the anodize is not very good, lasting for a short time then starts to flake.
I have heard of a couple of places that can do it completely in a single dip, not sure on how long it will last.
For me and what I do, it's not cost effective.
One thing to remember is once anodized you'll only need to keep it clean. But, once it starts to flake or yellow, you'll need to strip it off and do it again.
I polish, then seal with an aluminum sealer, just keep clean and it will look good. If dulling just polish it by hand with aluminum polish and seal again. You'll always have a bright shine and never have to remove the grille again.
Old Aug 15, 2014 | 09:24 PM
TBird Larry's Avatar
TBird Larry
Were the painted grilles the steel ones? Were they only painted white or were there black ones also?
Aluminum looks nice.
Old Aug 15, 2014 | 09:27 PM
daveengelson's Avatar
daveengelson
Actually found a shop that would anodize but the cost was prohibitive, in questioning the platter about having the grille chromed they suggested using the 65 steel grille rather than the aluminum, explaining there's a reason the aluminum grille does not have a high gloss. Having done a 'do it myselfer' I certainly will be in touch should I need to replace the grille.
Old Aug 15, 2014 | 09:56 PM
gangstakr's Avatar
gangstakr
I've only chromed steel grilles. I only polish aluminum.
Powder coating is another way to go, however the chrome is not a bright chrome finish. I almost powder coated a 67 grille but it was in near perfect condition that it had to be chromed.
There is a difference in the shine, but you pay dearly for a good chrome job.
Don't you just love the EPA?
Old Aug 16, 2014 | 08:20 PM
TxStang2010's Avatar
TxStang2010
EPA has left a lot of businesses bankrupt ...................... especially the plating businesses .
Old Aug 17, 2014 | 12:10 AM
1964FORDTUF's Avatar
1964FORDTUF
Originally Posted by gangstakr
Most likely the anodize is shot or will be when trying to remove the paint. Either way, if you really want to tackle the polishing, it's not difficult.
It is time consuming when doing it in your garage, but it can be done.
I personally polish my grilles. Here's a few pictures of one of my 65 grilles I did for a customer.
SWEET!! If I ever get my grille from a certain somebody Im polishing the polish areas just like yours...thanks!
Fords & Whalers
15
Jul 29, 2018 07:17 AM
Fords & Whalers
Dec 20, 2017 06:33 PM
pkenn7
Nov 1, 2010 10:03 PM
paramedic624
16
Jan 14, 2005 03:09 AM
Toreador
2004 - 2008 F150
24
Oct 29, 2004 12:35 AM
