I Pulled my 302 apart and have found I will need to rebuild the whole shabang. New Pistons, rings, lifters push rods, valve job, re-bore cylinders, timing chain, camshaft, all new seals (naturally),bearings.
I noticed alot of people rebuild their motors and im wondering how an earth someone could justify a total rebuild instead of buying a long block with a warranty. The only thing I can think of is the joy of actually rebuilding the motor because its certainly not cost effective to replace all of the above. Could it be im just going to the wrong places for parts. I'm just trying to rebuild my motor to stock or as close as possible.
I can think of at least a couple of reasons.
<ul>
The pride of doing it yourself.
To keep it a numbers correct vehicle.
You can pick your machinist.
You can pick what machining work you want done.
You can pick what parts are installed.
</ul>
These are all reasons I rebuilt my 351w myself.
I can understand the pride and quality issues. I can also understand the keeping everything original issue. But, I can get a long block from Carquest for just under $1200 with 3year warranty unlimited miles here local. I cant get parts and machining for less, plus if something goes wrong no warranty. I just cant justify paying nearly the same or more to do it myself.
I think we are comparing apples and oranges here.
If you are looking for a mass produced economic solution than a reman long-block is the answer.
If on the other hand you are looking for a solution created by a craftsman or as a statement of pride you should look elsewhere.
Dont get me wrong I would love to rebuild the motor. I just dont have the money to do it. There certainly would be a sense of pride in it. On the other hand I plan on using this truck as a daily driver. That means I need to get him running as soon as possible and as cost efficient as possible after pricing parts It was right at the same amount as a reman longblock. As far as mods well it doenst come with an intake or carb or exhaust manifolds so to that minimal extent I can do what ever i want and thats all I would really have changed anyhow. I am by no means an engine guru I would have put as close to stock cams and lifters and so on in the motor any how. pistons were gonna be cast. Rods werent gonna be anything fancy.
But I fully understand the pride issue I was really hopin to rebuild the engine and be able to tell people I had. I had big plans of a sweet looking clean repainted motor and engine compartment as close to original as possible.
If you'd like my personal choice: get a genuine motorcraft rebuilt motor, preferably through advance auto. very cheap, 4 year warrenty and built to factory specs
we just put a 302 in a service truck and have had no problems or any complaints for the last 8,000 plus miles
again, i've had my fair share of builds, and work at a shop, so i see how expensive labor can get. somtimes it's just easy to get the pre assembled motor and drop it in. Cheapest and safest way to go IMO.
