Power Point Fuse Location
Old Aug 12, 2014 | 08:11 PM
escape42's Avatar
escape42
Anybody happen to know the location for the Power Point (lighter) fuse?
I checked the fuse box but the label wasn't clear.
Thanks in advance.
Old Aug 12, 2014 | 09:37 PM
Wheelman55's Avatar
Wheelman55
On my 1993 F250, it's fuse #9 in the panel inside the cab. It's a 15 amp fuse.
Old Aug 13, 2014 | 08:06 AM
rla2005's Avatar
rla2005
What year/model truck are you asking about?
Old Aug 13, 2014 | 08:15 AM
subford's Avatar
subford
On your 1995 F250 the lighter would be fuse #16 (15AMP) and the power point would be fuse #9 (25Amp) in the IP fuse panel.
Power Distribution
The Generator and Battery are connected together at the Starter Relay hot terminal. Other circuits originate at the Starter Relay hot termianl and are protected by fuse links. Low power circuits are protected by fuses.
The Ignition Switch and Main Light Switch are powered at all times, as are the Fuses 1,4,8,12, and 16. The other fuses are powered through the Ignition Switch or the Main Light Switch.
Old Aug 13, 2014 | 11:12 AM
escape42's Avatar
escape42
It's a 1995 Ford F250 v8.
work.truck
Mar 16, 2015 08:07 AM
work.truck
Electrical Systems/Wiring
Mar 12, 2015 11:26 PM
Macs1964F100
Jul 7, 2014 04:45 AM
myblkexpy
Feb 6, 2011 09:02 AM
rlporter507
Dec 27, 2010 11:45 AM
