Front End Rebuild Alignment issues
Old Aug 12, 2014 | 09:12 PM
Z3T3C's Avatar
Z3T3C
Trailering
Originally Posted by quaddriver
btw - I just did my 90 in jan/feb timeframe - every single front end part. you absolutely MUST have a driver in the seat when camber is measured and toe/cross steer is set. The truck has up to 19 gallons of fuel and a driver on that side and it DOES make a difference on the rack.
Even more for my truck. I have an XLT with the 8 ft. bed and dual tanks. Hey maybe they will let me sit in my truck while they work Maybe I will just fill up the secondary tank before it goes in.
Old Aug 12, 2014 | 10:49 PM
krooser's Avatar
krooser
Find a shop that does heavy duty truck frame work, alignments, front end work, etc. Those guys are usually experts at this stuff.
I've had several different pick-ups done at one shop in Appleton, WI and have never had a complaint. These puny little F-series are like working on tinker toys to those guys… they have big tools to do it right.
Old Aug 13, 2014 | 03:00 PM
Z3T3C's Avatar
Z3T3C
Trailering
It is not so much the lack of tools as, I believe, it is a lack of knowledge. However, I'm sure those guys know far better of what they are doing. Never considered taking my truck to a rig shop, but probably would have been a good idea.
I bit the bullet and went to the Ford stealership. Turns out my wife's friend's fiancé is a tech there.
Old Aug 13, 2014 | 03:06 PM
Evan_P's Avatar
Evan_P
I had mine done at the local dealer. Best $60 I spent. The alignment was perfect, wheel perfectly strait. Been 2 years now and 12k miles and the truck still tracks perfectly strait and wears the tires nice and even. The tech that did mine has been at the dealer for 35+ years and specializes in alignments. He does just about all of them that come through.
Old Aug 13, 2014 | 03:48 PM
krooser's Avatar
krooser
These truck shops work on almost nothing but solid front axles…lots of experience there. They have the equipment to do it right… I was a trucker for 41 years and I have seen them fix a lot of front ends that others screwed up.
It won't cost you anything to check 'em out.
Try these guys…
Truck Repair Des Moines Iowa :: Majestic Truck
or these…
United Truck and Body
roughridn_sob
Feb 3, 2017 07:30 PM
HJM/F250
Jan 9, 2016 07:05 AM
nickt916
Nov 4, 2013 08:46 PM
Chevy Guy
17
Jun 18, 2004 12:12 AM
knuckles69
1978 - 1996 Big Bronco
Mar 31, 2003 07:19 AM
