Rear Differential
Old Jul 12, 2003 | 12:06 AM
MCalvin460CI's Avatar
MCalvin460CI
Rear Differential
I HAVE A 1996 FORD EXPLORER AUTOMATIC 4X4 4.0L V6 WITH TOW PACKAGE. I WANNA CHANGE THE DIFF FLUID ON BOTH FRONT AND REAR. WHAT FLUID DO I USE AND HOW MUCH IN EACH? WHAT TOOLS DO I NEED? HOW HARD IS IT? HOW MUCH FRICTION MODIFIER TO THE REAR? THANKS FOR YOUR HELP
Old Jul 13, 2003 | 09:44 AM
AdiDcn's Avatar
AdiDcn
Rear Differential
i used grease on front diferential rear i cant yet need lots of grease
Old Jul 13, 2003 | 04:40 PM
CNTHOR's Avatar
CNTHOR
Rear Differential
The rear uses 90w gear oil with 8oz(i think) of the friction modifier if you have a limited slip (which you do if you have the tow package.
They sell the friction modifier in the exact size you need.
My 95 dana-ifs35 front end uses a synthetic fluid (not supposed to need changing) a 100,000miles. But even the ford dealers ussualy put regular 90w back into it on a change. it just means you have to change it every 50,000 or so
