Cigar / Cigarette Lighter and Socket
If I want to install one, mainly for charging a phone or running a 12V air pump, and I also want it to be able to look stock, meaning I want the socket AND the lighter w/ bezel, I am a bit confused:
Dennis Carpenter has what appears to be all three pieces for Dentsides, but only the element and well for Bumpsides. Will the Dentside kit not work or look right?
In the LMC catalog, I can't tell if I need 16, 17, 18, or some combination of those.
NPD is similarly confusing. It appears they have no **** at all for Bumpsides.
Also, is there any difficulty finding the right type of female wire to connect the socket to power?
The wiring may already be in your truck. Check for a space in your Fuse Box marked "Lighter" or "Cigar". Probably a 15 Amp or 20 Amp fuse. There should be a wire with an unused female connector under the dash near where the lighter would be located. It may be a Blue wire with a White stripe. It plugs in to the back of the "Lighter" assembly.
There should also be a small Light Blue wire with a Red stripe. This wire is for the little bulb on top of the "Lighter" socket assembly.
I hope this helps.
The female end threads onto the male stud of the socket, the plug of the wire pushes onto the male end.
1973: Ford replaced the 1967/72 **** & element (C8TZ-15052-A) with the 1973 type (D3TZ-15052-A). Ford did not sell the **** only.
1973: Ford also replaced the element used 1967/72 with the 1973 type. It will work on 1967/72's, but the '73's ash guard (marked LIGHTER) is smaller in diameter than the original.
1967/72 F100/750: The dealer installed lighter kit (C8TZ-15A044-A) came with the wire, so I doubt it's present in the OP's truck. The kit does not include the fuse.
FEW-14429-A .. Lighter Fuse / Obsolete
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 2 = 812-359-4965.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 5 = 800-476-9653.
TISON MOTOR CO. in Estill SC has 10 = 803-625-2551.
C8TZ-15A044-A .. Lighter Installation Kit-Includes **** & element, socket, wire and instruction sheet / Obsolete
MCDONALD OBSOLETE PARTS CO. has 1.
NOS PARTS LTD in Waxahachie TX has 1.
CARPENTER NOS OBSOLETE PARTS has 3.
C8TZ-15052-A .. Lighter **** & Element / Obsolete
CARPENTER NOS OBSOLETE PARTS has 1.
