front fender to cowl
Old 08-11-2014, 07:15 PM
zombiefied 247's Avatar
zombiefied 247
zombiefied 247 is offline
what size bolts should be used to attach the front fenders to the cowls ????
Old 08-11-2014, 08:40 PM
dmack91's Avatar
dmack91
dmack91 is offline
I don't know what year you have, but I believe I used a 3/8" bolt for the top rear of the front fender to the cowl, while the lower mount was a 5/16" stud on the frame. The top of the fender bolts to the inner fender with 5/16" bolts, as well as the grill and upper pan bolts.
Old 08-11-2014, 08:59 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
Zombiefied, if this is your '55, they are 5/16" x 3/4". From the factory they were fine thread (24), but the coarse thread (18) is good too.
Old 08-12-2014, 08:06 PM
zombiefied 247
I keep forgetting to put my truck year in my post sorry about that. thanks for the info guys
Old 08-12-2014, 08:11 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,195 Likes on 2,688 Posts
You could put the year and model in your sognature and it would be there in all your posts.
Old 08-12-2014, 08:27 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
You've gotta use the 5/16 UNF bolts on the cage nuts on the cowl. Same with any of the threaded nuts on the radiator support, J nuts on the grill etc. If you need nuts and bolts I.E. Inner fenders to fenders you can use 5/16 UNC. I just use UNF for all of them so I'm not tempted to use the wrong bolt in the wrong place.
Old 08-12-2014, 08:30 PM
EffieTrucker
I forgot about the threads in the radiator supports. Thanks for pointing that out.
shlby
20
06-08-2019 09:46 AM
tigerfan79
05-06-2017 09:35 PM
MARC
02-04-2013 12:37 PM
DR Smith
02-12-2008 12:04 AM
BoomerPower
01-22-2005 10:49 PM
Quick Reply: front fender to cowl
