bleeding brakes
Old Apr 28, 2002 | 04:54 PM
fordtuff101's Avatar
fordtuff101
bleeding brakes
fordtuff
I have a 1988 F250 4x4.
The brakes need to be bled, but on the left front the bleeder valve is broken off. Is there any other way to bleed it without replacing the whole thing?
Old Apr 28, 2002 | 05:35 PM
orange peel's Avatar
orange peel
bleeding brakes
you could just take off the brake line at the brake and just let it bleed straight from that, i think that would work.
Old Apr 28, 2002 | 08:08 PM
GammaDriver's Avatar
GammaDriver
bleeding brakes
I would think the chance of getting air in the line after reconnecting would be too high to do it that way... but if you've heard of people doing it...
how about an EZ out made to get broken bolts out? Since the hole you would have to drill is very nearly already there in the bleeder bolt, it might work if you're careful.
And I guess that if you really wanted to save the caliper (it's probably about time to change it for a new one anyway), you could have someone drill and tap it for a new bleeder screw if they knew where to drill.
Old Apr 30, 2002 | 06:31 AM
fordtuff101
bleeding brakes
fordtuff
Thank you,for the advice.
We found out that the front bleeder valves are directly
connected to the pistons, in the front so the whole thing
will have to be replaced anyway.
Old Apr 30, 2002 | 06:33 AM
fordtuff101
bleeding brakes
fordtuff
We thought of using the EZ out to, for the rear ones.
Thank you for the advice.
Old Apr 30, 2002 | 07:37 AM
winfordr's Avatar
winfordr
bleeding brakes
