well its been awile but the frame it totaly stripped down got some rust repair on one cab mount to do then going to have it powercoated
ill try to get some pics up soon
id have to go look but think it was 177k pretty much original drivetrain except for an engine freshen up at 99 k due to a dropped valve was expecting a damaged piston so it was pulled out for a rebuild and oddly enough the intake valve hit piston once got bent and wedged under ex valve and did no other damage so it got the head fixed rings and bearings and ran well like a 351m always does slow from then on
