finally! official thread!
#228
#229
#230
heres the crossmember!
everything installed! now i gotta adjust the drive shaft length.
linkage needed some grinding as did the floorpan
this random valve cover i have, that fits my rockers
heres the stock one and it doesnt appear to hit. ill install it and see if it hits then ill powder coat it.
also installed the starter, gonna be real fun if it ever goes out:/
#234
The stock cable is two inches too short, I can unplug it from the ttb crossmember and it'll reach. I'm going to get a new cable and bring it around the back. But I will put a shield around it. I'm going to get it driveable and then trailer it down to my base and do little things like that cable, my skid plates, rear brakes, and some more painting. Also I might heat and bend my t case shift lever down some, that is in 2h the way it sits. also either custom shifter or something
#237
#238
Oh man I know! I'm so ready to have it down there. I'm gonna get it driveable enough to make it to my house, ten miles down the rd, and onto the trailer. Load up my new tires, load up my skid plates, and all my other fancy stuff that isn't necessary and then haul it down, drive it an hour or so every night and wrench in it everyday.
I'm not excited about my giant radiator however. My stock on is about a finger width. The new one, a 460 radiator, is about a hand width.
Also in the Carolinas, what is a good thermostat rating? My stock was 195, and the new one I have is 180.
I'm literally at the point where I can start putting it back together and I couldn't be happier. Hi got to a spot where I lost motivation and was getting aggravated, but now that the motor and stuff is together, it's like right here and annoying how close I am to driving it.
#239
