Eastern Oregon HELP!!!!
Old Aug 8, 2014 | 01:12 PM
militaryvet1428's Avatar
militaryvet1428
Exclamation Eastern Oregon HELP!!!!
I am replaceing the clutch and transmission in my 1989 F-150. this is the first time I have done this and I have no idea what im doing. Is thare someone in the area that could help me? I will pay for your time if need be. Thanks in advance!
Old Aug 8, 2014 | 09:34 PM
Old93junk's Avatar
Old93junk
Which motor does your truck have? 300-6 or 302 (5.0L) or 351 (5.8L) V-8s
I have found it easier to deal with transmissions in Rangers if you pull the engine, leaving everything in open view and less time grubbing around on the ground.
Old Aug 8, 2014 | 10:37 PM
militaryvet1428
its a 5.0 v-8 2 wheel drive
Old Aug 8, 2014 | 11:37 PM
Old93junk's Avatar
Old93junk
Easiest scenario, much better than 4wd. Drop the exhaust, drive-shaft, get/rent a trans jack, loosen trans crossmember, remove slave cylinder, remove bell-housing bolts, wires, speedo-cable, remove the trans mount, (support with jack) remove crossmember, slide back and drop trans.........everything is exposed to work on.
Old Aug 8, 2014 | 11:44 PM
militaryvet1428
I already have everything torn apart i just need help putting it all back together again. Lol
Old Aug 9, 2014 | 06:23 AM
fabmandelux's Avatar
fabmandelux
FTE Remembers
Where in Eastern Oregon? I live in Condon.....
F-erOnlyRunsDwnhill
Mar 30, 2014 05:16 PM
michellers
1947 and Older Ford Trucks
Jun 16, 2012 11:01 PM
volks
Feb 24, 2011 10:05 PM
Charger73400
1983 - 2012 Ranger & B-Series
May 8, 2005 08:26 PM
Rat wagon
Feb 18, 2003 01:45 PM
